2006 is250 fuse box to disable AFS
Hey guys,
any help on which fuse is needed to be removed in order to turn off the AFS blinking lights?
i don't have the manual and i'm having a hard time figuring out which fuse relates to the AFS
thanks!
thanks!
Check under your car near the driver's side rear wheel. If it looks like this when laying on your back looking up, the rear AFS sensor is in the wrong position (probably from a suspension install), causing the AFS light to blink.
It should look like it does below (from 1:23
). That video also mentions how to adjust the height of the lights which may be necessary if you're lowered.
If you need to change the sensor position, don't remove the nut from the bolt attached to the sensor housing, or it may snap the bolt...learned that the hard way after the shop that installed my suspension didn't pay attention to this sensor.
blk250
08-10-08 12:32 PM
