Last edit by: IB Advertising
Browse all: Lexus IS Brake Guides
- Lexus: How to Replace Brake Line
Step by step instructions for do-it-yourself repairs
Stainless Steel Brake Lines
Think about it, there is a certain amount of hydraulic pressure the system generates through the brake booster. If the OEM lines can handle that pressure, even if replacement lines can handle more, there isn't more to handle.
Just ordered stoptech brake lines. Should have done a search first. I understand that the OEM rubber lines will perform just as good as stainless ones on the street. What about the track though? I track my car quite a bit and I was under the impresson that stainless lines will hold but better to the high heat generated under track conditions. Am I incorrect here and the OEM lines are just as good?
