Transmision acting weird
So lets say I'm driving and I see a stop sign. I do not come to a full stop, but almost there and it feels like the optimal gear to move forward would be 2nd, but once i push accelerator car shifts to 1st gear (revs 2-3k) and then quickly shifts to 2nd. And once it shifts to the first gear you can really feel the pull.
Also if i push it very gently then i don't get that pull but car still shifts to the 1st gear and revs ~2k
Any ideas?
Any ideas?
you should always come to a complete stop at all STOP signs.....problem solved, you'll start in first.
Nah, for real though, how many miles? Is it in ect power mode?
Thanks! Will do that tomorrow morning and hopefully this will solve the issue.
Mine does the same thing, its annoying but seems to be normal. You can also set it in snow mode when your going to be doing a lot of start stop start stop and that makes the car start out in 2nd instead of first.
So i reseted my ECU today and overall I can notice a smoother shifting. As far as the described issue I need to do more driving, but the car still shifts to 1st gear. Although If you go really easy on the accelerator its definitely smoother.
EDIT: Did some more driving and now issue is completely gone! it doesn't use 1st gear if you go easy on accelerator
i have a 2007 ES 350 and im having transmission issues too when i get in the car in the morning start the car and put i in Drive the trans goes in and out of gear and you can not drive it it also does it in revers for a hour at least after that it can run normal all day we replaced the transmission put a used one in and still has the same problem
can anyone help
can anyone help
