Window/door/steering/led light question
Sorry I did a search...and I don't mean to add another how to question, but the amount of research that I have done I am still concern about the next mod I will be doing.
I want to change out all my LED lights that are in my buttons from windows to vents and radio.
I notice the model number leds required ex: 603 and 1207 and 4mm 5mm etc.
but the problem I am having is when I go to these website to order them I don't see anywhere written that these bulbs are model 603 or 1207 I just get (MM) sizes.
Is there a post where I can buy all the bulbs I need through one website or do I have to purchase from other sources? Installing them is not my issue purchasing the right make for the car is..its more confusing then finding the right HID model bulb for the car lights lol.
I know I am not the only one with this same concern I am just the first to bring it up I guess.
I just need a good website were I can purchase all the leds and if at all possiable links to the bulbs I want to do the whole Nav, steering, window buttons in White. With the radio Vol and Tuning in blue
TEMP: Will be in Red and Blue
Cig lighter in White
Vents in White
and the selector color for A/C or vents in Green
the ignition I havent decided on them yet
Thanks in advance
These are the sites I been to already and its like a needle in a hay stack to find
http://www.niktronixonline.com/
http://www.superbrightleds.com/
http://www.oznium.com/
http://www.autolumination.com/
http://www.unique-leds.com/
Picture below represents the look I am after
Vents in White
Thanks in advance
leds (buy extras for 0603 and 1206 and stick with the same mcd)
pwr/ect/snow: 4mm neo4-xhp
traction: 3mm neo3-xhp
trunk/gas: 3mm neo3-xhp
rear window shade: 3mm neo3-xhp
seat warmer: 2x 5mm bicolor 3 legs, neo4-4
start button: 5mm bicolor 3 prong, 3mm
a/c vents: 4x 3mm
radio/cd eject indicator: 22x 0603
volume/seek /cd load indicator: 18x 0603
< O >: 3x 1206
a/c indication row/security indicator: 17x 1206
clock: 8x 1206 (i only changed out 7 because no point in changing hazard)
power windows/locks: 8x 1206
navigation: 51x 1206
parking: 74-x or 74-xhp (if you want it brighter)
cig lighter: 74-x or 74-xhp
steering wheel: 7x 1206 or plcc-2
if you plan on doing ur cluster then:
Speedometer is 8050 but could used 0603 0r 0805
other stuff : 1206
http://www.unique-leds.com/index.php...ategory_id=160
a/c vents: 4x 3mm
< O >: 3x 1206
other stuff : 1206
crappy cell phone pic but this is what i have done...You can see the radio buttons dont color match with nav part so make sure that doesnt happen to you. I am working on color matching the radio buttons right now.
0603 Surface Mount Led - Blue 380mcd Max
0603 Surface Mount Led - Purple
i should get it Monday or so and i will let you know asap. Thanks
wcoastls
05-14-11 09:09 AM
