do i just need replace the bulb?
Old 05-08-11, 07:30 PM
vi3t80y
vi3t80y's Avatar
Default do i just need replace the bulb?
i want get risk of the drl yellow.i want get the 5k bulb.my question is im just need replace the bulb or do i also need to get the convertion kit to work with 5k bulb?because i know the original drl only 4300.Thanks anyone help me out
Old 05-08-11, 07:53 PM
new.era.13
new.era.13's Avatar
it will still look yellow. DRLs run at 30% power, you will only get the 5k look when its at 100% power or changing to LEDs, but that will remove the high beams.
Silkky
Silkky's Avatar
Are you going to replace it with another halogen or LED?
Halogen bulbs will be just a straight replacement while if you go LED, you have to get the module so it doesn't flicker and it'll run at 100% power.
Old 05-08-11, 07:56 PM
Silkky
Silkky's Avatar
Has anyone ever done halogen with module so high beams = DRL? :P
Old 05-08-11, 08:14 PM
vi3t80y
vi3t80y's Avatar
i mean if if i just want replace the bulb to 5k.is it gonna work?
Old 05-08-11, 08:17 PM
Silkky
Silkky's Avatar
Yes but no matter which bulb you get, it'll be running on half power so it's not going to be pure white.
Only way to get 5000k to look like 5000k is LEDS with module.
Old 05-08-11, 08:18 PM
vi3t80y
vi3t80y's Avatar
oh then you think i should by the one with module and have harrness hook up to battery
Old 05-08-11, 08:23 PM
Silkky
Silkky's Avatar
No, you don't need the relay harness.
Just get the LED bulbs and the modules.
Old 05-08-11, 08:25 PM
vi3t80y
vi3t80y's Avatar
is this the one
http://www.v-leds.com/Vehicle-Specif...71398-1-3.html
or this one better one?
http://www.v-leds.com/Vehicle-Specif...-p9167453.html
Old 05-08-11, 08:28 PM
Silkky
Silkky's Avatar
1st one but I thought you wanted 5000k?
Old 05-08-11, 08:32 PM
vi3t80y
vi3t80y's Avatar
yes they also have 5k.if i want replace the fog to match with the drl and headlight.is the 1st also work with fog?
Old 05-08-11, 08:42 PM
Silkky
Silkky's Avatar
You will need 9006 bulbs for the fogs.
9005 = DRL/High beam
9006 = Fog
I have a pair of 9006 white 6000k bulbs for sale if you are interested.
https://www.clublexus.com/forums/gen...-9006-hb4.html
Old 05-08-11, 09:08 PM
vi3t80y
vi3t80y's Avatar
do i need module for the fog light to work with 6000k bulb?whats reason you sale it?
Old 05-08-11, 10:01 PM
Silkky
Silkky's Avatar
You don't need module for the fogs since it'll always be running at 100% power.
I decided to go yellow HIDs for my fogs.
Old 05-09-11, 01:17 PM
DreamerzCC
DreamerzCC's Avatar
the vleds drl upgrade with module will only work in the off and city lights position. once the headlights are on the regular DRL's come back on.....or thats what happens with mine.
Quick Reply: do i just need replace the bulb?
