Tire Sensor Warning light
06-18-10, 02:51 PM
Just installed 20inch rims with out sensors on them how do i get the warning light to go off ?
06-18-10, 03:02 PM
u need to put TPMS sensors in and bring it to the dealer to program it. you can program up to 2 sets of TPMS. GLWUM
06-18-10, 03:35 PM
well theres strikes 2 and 3 right there...unless you put the sensors in your dubs, the light wont go off.
06-18-10, 04:23 PM
sensors
there has to be a override somehow ?
06-18-10, 04:27 PM
There is a way to trick it by sticking it into a PVC pipe and then pressurizing it with air.
We call it a "pipe bomb"
just do a search for pipe bomb
06-18-10, 05:11 PM
perhaps i should look up Shadow Man under Clowning
06-18-10, 05:45 PM
Quote:
Originally Posted by
jiggy211
No, there doesn't.
The TPMS system is required by federal law.
As mentioned you can put the 4 sensors in a pressurized canister (or some folks put em in their spare, which means you can't use the spare, but with 20s you're not likely to anyway).
But you can not get around the system requiring 4 active, pressurized, sensors nearby and working.
06-19-10, 01:02 PM
Good advice thanks but how do you put 4 sensors in one spare
06-19-10, 01:47 PM
Fire Slayer
The guy I bought the car from put it in a hand truck tire. It's in the trunk and fools the car. Its similar to the pipe bomb.
06-19-10, 02:12 PM
I'm glad you posted this because I just put on 19's and i have the same problem. So which would be better, putting them to the tire or in a PVC pipe?
06-19-10, 10:37 PM
ABurns250
If I were you then I would get those sensors on the wheels. If your 19s aren't compatible with the sensors. iForged sells sensor brackets.
06-20-10, 07:37 AM
Yeh I bought work varianza's and the guy was like you can tape or glue them to your wheels I was like yeh....no hahah
well thank you I'll have to check that out
mjclsi
GX - 1st Gen (2004-2009)
20
08-02-17 12:58 PM
ThumperPup
ES - 5th Gen (2007-2012)
03-03-15 11:55 AM
RoseHill1
12-28-13 03:35 PM
madmaxoo7
08-17-13 02:24 PM
dappy
08-05-08 10:20 PM
06 ,
2009 ,
federal ,
law ,
lexus ,
light ,
pipe ,
pvc ,
sencsor ,
sensor ,
sensors ,
tire ,
tires ,
warning ,
wont
