Any problems with 6k low and 8k fog during the raining season?
I have 6k low and 8k fog right now.....my freinds told me that I may not able see the road when it is wet...it is all about safty ....(eventho I like the look right now)so......is my friends telling me the turth?Do I have to replace my fog bulbs before the raining season comes?if yes....how many K should I put on my fog?
Thanks!
Thanks!
the 6k and 8k are more for looks true but your output should be at oem lighting at this point maybe a tad bit worse.
a real nice setup would be a 4k 4,300k low and yellow 3k light anything under 5k is bright enough.
I'm running the same setup, 6k low 8k fog and I haven't had any problems when it actually does rain in Southern CA. Like others will tell you, you'll get lesser output when you go higher. I think stock HID's on our cars are 4300 or 4500 so anything close to that range will be perfectly fine.
ur friends are telling the truth but its not that big of a deal..anywhere from 4000-5000k would be the best output for your lows in rain, and i personally suggest 6000k for looks and safety in one. as of fogs, 3000-4000k..mix it up your way. i run 8000k lows n 3000k fogs n i really never have a problem, but i also drive 5% tint front/rear no problem so i might just be crazy.
