Calibrate new rearview mirror?
Old 09-25-07, 01:31 PM
evotolexus
evotolexus's Avatar
Default Calibrate new rearview mirror?
Just had my rearview mirror replaced under the TSIB. However, noticed the tech didn't calibrate it. It shows "cal" on the display. Figured I'd check here before I call the dealer.
I searched and found the calibration directions for the older GS models.
I went to the dealer for the rearview mirror TSIB and Aux port TSIB. Rearview mirror was in stock, but not parts for the Aux port. Also, my passenger side mirror stopped working; so that's on order too.
Thanks.
Old 09-25-07, 02:05 PM
jimjaix
jimjaix's Avatar
what's the TSIB for the rearview mirror? can you post the pdf file?
Old 09-25-07, 02:18 PM
tex2670
tex2670's Avatar
It's in the manual--you're supposed to drive around in circles. I never did it, but the CAL went away by itself.
Old 09-25-07, 02:54 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
The mirror TSIB is for a vibrating mirror.
The CAL just needs to be calibrated. Press compass, safely drive in circles, and the compass will calibrate itself...
Old 09-25-07, 03:25 PM
ben_r_
ben_r_'s Avatar
Do a search and youll find a long thread on it that I created.
Old 09-25-07, 03:28 PM
evotolexus
evotolexus's Avatar
Read the manual:
1. Set the zone by holding "Auto" until a number displays.
2. Select zone by pressing the "Auto" button until you find your region.
3. Number will disappear.
4. Drive around in a cirlce at about 5 mph until "cal" disappears.
5. If unable to drive in a circle, drive around the block.
Had to read manual on how to program a "rolling code" for a garage. I forgot to synch up to the remote before doing the "learn" function.
Thanks.
Old 09-25-07, 03:36 PM
4TehNguyen
4TehNguyen's Avatar
had cal for a day or two, then it just went away, I didnt really do anything
Old 09-25-07, 04:56 PM
Namir
Namir's Avatar
haha, i can just picture a parking lot full of new IS owners driving in 20ft circles
Old 09-25-07, 05:31 PM
Hartawan
Former Vendor
Hartawan's Avatar
I just got mine done today, so does the homelink buttons all reset?
Old 09-25-07, 05:43 PM
evotolexus
evotolexus's Avatar
Yes, because it's a whole new mirror. So you'll have to calibrate as well as reprogram the homelink.
Old 09-25-07, 06:13 PM
VikH
VikH's Avatar
Guys who did the TSIB: Are vibrations in the mirror less?
Old 09-25-07, 06:15 PM
Hartawan
Former Vendor
Hartawan's Avatar
I dont have ML so my sound system has more kick to it. When I play music with a lot of bass, I can tell the difference, it doesnt vibrate as much. However, as I was driving back home on the freeway, it was still shaking. And I dont quite remember what it was like before.
Old 09-25-07, 08:24 PM
evotolexus
evotolexus's Avatar
Yes, definitely a big difference. I have ML and the shake was terrible. I'd say it cut out about 90% of the shake. It's more of a small vibrate at high volumes with a lot of bass.
Old 10-20-07, 07:39 PM
nsxiboi
nsxiboi's Avatar
I don't have my manual with me. Anyone able to help me find out the zone number for Stockton, CA?
Old 10-20-07, 09:09 PM
Evitzee
Evitzee's Avatar
Yes, the CAL will go away eventually, but your compass won't read correctly, depending on where you live and the effect of the magnetic declination at your location. Take a look at the manual, you need to set the compass to the number to where you live to get the most accurate reading. It's a five minute operation. Just do it.
Quick Reply: Calibrate new rearview mirror?
