Winter tires on 18" oem staggered
Greetings,
Anyone try winter tires on stock 18" staggered sizes? I was told thinner the better for snow so was thinking about running 225 both front and back. Any suggestions?
Will 17" be better in terms of traction? i doubt it since it's the width and rubber compound that makes the difference in snow.
Thanks!
Thanks!
Your right, the width of the tire will be the same. The advantage with a 17" winter tire is better rim protection with 45 sidewall instead of 40. I believe you need 225/45/18 in the back to fit the 8.5" rear wheels. Posted here:
https://www.clublexus.com/forums/sho...d.php?t=237765
