Aftermarket HID issues
Originally Posted by Tmirk
Why not just not use the auto function if that seems to solve the problem?
Steve what kind of relays do you guys use, and is there 1 or 2 relays per harness?. Also I suspect the harness being the culprit in all of these cases, I would check all the grounding points and make sure they are touching bare metal because a bad ground can cause these kind of problems. The fact that the ballast do turn on most of the time seems to indicate they dont get enough power so if I would suggest splicing into the ground wire thats connecting to the ballast and connecting it to a very good ground point on the chassy. I still would like to know what kind of relays are used since I heard theres 2 of them on xenondepot harness's this might be the problem since they arent turned on in sequence but simultaniously and causing the amprage fall below start up value. I suggest turning the headlights on while driving or reving the engine up a little to get more power to the battery that should solve the problem unless it's the ground wires ofcourse. Stan
i just got my xtreme 6500k from xenondepot installed by an audio place. I did noticed that when i turned the car on, only one of the headlight was on, i had to turn it off and on again then it was fine.
Based on the thread I wasn't sure to leave the light on Auto or off ?
Originally Posted by t0e
Dont be lazy. Do not leave your lights on AUTO--if you have aftermarket HID kit.
I always turn mine on the old fashion way and they work fine.
I've had the MTEC 6000K HID kit for 3 weeks now under normal operation in AUTO. I have never experienced a problem. I do notice when I first turn it on, the HIDs are not as bright (bluish) and becomes brighter after a few seconds (less bluish).
vietloc
12-12-08 08:16 PM
