GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
CD magazine issues
Old 11-10-08, 09:52 AM
bwallace2
bwallace2's Avatar
Default CD magazine issues
Is there an eject button for the cd sleeve in the 6 disc player that is in the glove box. Do you just push on the cd sleeve to make it release? I think my cd sleeve is stuck in the player and will not release to add or remove cd's. I hear a clicking noise ever time i close/open the cd door. A loud click like something is stuck in the player. I just had this serviced under the warranty, but believe it may still be broken. The entire cd mechanism in the glove box seems to move if i push on anything belonging to the system. It feels like its not all screwed in. Does anyone else seem to give a little if it is pushed?
Old 04-04-17, 08:38 AM
LrdAnkh
LrdAnkh's Avatar
Did you ever resolve this issue, I just bought a used GX 470 loaded the magazine and it wont play or eject it.
Old 04-04-17, 11:03 AM
chiph9
chiph9's Avatar
Mine ejects when you slide the door open. Are you leaving it open all the time?
Chip H.
Old 04-04-17, 11:08 AM
LrdAnkh
LrdAnkh's Avatar
No I do not leave the slide door open, I only open it when i am trying to eject the whole magazine but i cant eject it, when i close it and access the cd player it shows disc 2 loaded but wont play it.
Old 04-04-17, 11:23 AM
LoneHiker
LoneHiker's Avatar
The CD changer is a very cheap Pioneer unit with a bunch of plastic gears inside. At this age, the plastic gears are shredding for most people. I'm surprised anyone still has a working changer at this point. Replacement changers are available on ebay but they will break in the same way, probably in a very short time.
So yes, the magazine should eject when you open the door, but the changer is likely broken.
The solution is to add an aftermarket bluetooth interface (such as a vais) and forget about the changer. You'll have to take the changer apart to get your CD's out. When you take it apart, you'll probably see the broken gear(s).
Old 04-04-17, 11:49 AM
LrdAnkh
LrdAnkh's Avatar
I wish it had a place to put in an ipod connection, i have seen a cassette tape kind of doodad that can hook up to the ipod i will try that i have heard that those bluetooth adapters are not easy to install. Thank You for your help.
Old 04-04-17, 01:10 PM
LoneHiker
LoneHiker's Avatar
Yes a cassette adapter is the easiest solution but the sound quality isn't very good. Something like this one:
https://www.walmart.com/ip/Monster-i...r-800/32292366
If you want good sound quality, you'll want a bluetooth system such as the Vais SL3B-L:
http://www.vaistech.com/product/sl3b-l/
Installing the Vais does require taking apart some of the dash pieces to access the back of the radio to plug the connectors in. If you're not comfortable doing that, a stereo shop can do it, it shouldn't cost much in labor as it's an easy job.
Old 04-05-17, 05:44 AM
chiph9
chiph9's Avatar
Even better sound quality than the Bluetooth (but admittedly, not as convenient as streaming from your phone) is the VAISTech USB adapter. I have a 16gb stick loaded up with WAV files ripped right off the CDs, so it's just like listening to one (only no 6-disc limit, or broken gears)
Chip H.
Jontay
07-22-21 08:23 AM
Mazamin
09-12-17 12:20 PM
Charbel
02-14-11 07:41 PM
sktn77a
03-01-08 06:41 PM
Quick Reply: CD magazine issues
