CD Changer and cassette player not responsive.
Old Aug 21, 2017 | 07:11 PM
Mazamin's Avatar
Mazamin
Default CD Changer and cassette player not responsive.
Hi
i joined the Lexus club owners by buying my Lexus just two days ago. With 200K miles on it, I did not expect every feature to work. The are problem with the CD changer and the cassette player as followings.
I have read through a few threads here before, but most of those most of them were about jammed CD changer. I have Navigation system.
Cassette Player: I know that there is a cassette in the player since it plays it and I hear the sound, but it doesn't eject the tape. When I press the eject button I hear the sound of some mechanical actions/engagements in the player but the door never opens even with some force.
CD Changer: the things seems to be even less or not responsive. When I press the Load button nothing happens, even no green light comes on. I do not hear any mechanical sound either. When I press Eject button for 2-3 seconds, it beeps once and nothing happens again. I am not sure if the previous owners had left any CD in it or not. I get "CD-Error". The CD door, seems not to open if I want to force in a CD.
What I did are:
1- Unplugging negative cable of the battery, and reconnecting it after 4-5 minutes. No change in outcome.
2- Found 5 fuses related to Audio System, took them out and put them back after 5 minutes. No change in outcome.
3- Hit the sides and above the CD changer (as was suggested in some threads), while pressing the CD Eject button. No change in outcome.
I don't care about the tape, but I hope the CD works with not much money. Any suggestion is appreciated.
Thanks
Old Aug 23, 2017 | 07:39 AM
Mazamin's Avatar
Mazamin
Any thoughts on this?
Old Aug 23, 2017 | 10:13 AM
jimbosr1's Avatar
jimbosr1
Veteran: Air Force
you can try to pry the cassette with a very small bent object while pushing the eject button and see if if gives up the cassette.cant hurt.
Old Aug 24, 2017 | 11:40 AM
JffGRY706's Avatar
JffGRY706
about the cd player, there are indicators on the display for how many cds are loaded. 1-6. are they lit or not? error 1 is cd is dirty or damaged or upside down. error 3 or 4 indicates there is trouble inside the system pg. 286 of manual. there is no error 2 listed. when I push load it says wait orange glow and load when green glow appears. after ejecting a cd it usually says load.
Old Aug 28, 2017 | 02:21 PM
bloomwcjkl's Avatar
bloomwcjkl
The cassette on my 2001 LS 430 is completely dead. The CD changer works.
If I try to put a cassette in, there is no attempt to pull it in or play. It just goes in and gets stuck.
Could this be a fuse issue if only the cassette is dead?
Old Aug 30, 2017 | 10:37 AM
Mazamin's Avatar
Mazamin
JFFGRY706
I do have the Navigation system, and on my screen shows CD buttons 1 through 6, but the buttons are light gray. Does it mean nothing is inside? Also the error that I get is only "CD-ERROR".
Thanks.
Old Aug 30, 2017 | 11:55 AM
JffGRY706's Avatar
JffGRY706
I believe your cd player is full. when empty the numbers do not appear.
Old Sep 11, 2017 | 09:11 PM
Mazamin's Avatar
Mazamin
Yaaay!!. I fixed it. How?
On Ebay I found a used Cassette/CD Changer in our town (Austin, TX). I visited the seller and tested it the CD player didn't work. Because the owner (a used car dealer) was saying that it worked, I took his word and concluded that probably the cables/harnesses were bad. I took it to three Auto Audio stores (in less than 15 minutes!!), but they said only Lexus dealers can repair it in our town, or a particular audio repair shop in our town. I took it to the repair shop and told the owner that probably there is something wrong with cables. He said No, because he knows such systems are prone to failure, but he can fix it. To support his opinion about the faulty deice not cables, he pointed out to the the CD-loading cover (door) that was not fully closed (vertical) but was with some angle. I had seen that angle but had thought that it might be OK.
For how much would he fix? $350 including tax. I could not afford it. I decided to try to fixed it for the last time by only focusing on fixing the door. I disassembled the faceplate of the CD-Changer. and disassembled a couple of PCB's and all the small mechanical parts to the very last component, and then could turn the door to make it vertical. Put everything back, and then you guess it: the device started initializing itself and then loaded, played and ejected the CD flawlessly. I was very proud of myself (haha) and saved $350!!
Old Sep 12, 2017 | 07:41 AM
imdking's Avatar
imdking
Way to go!
Enjoy your music!
Old Sep 12, 2017 | 12:20 PM
Mazamin's Avatar
Mazamin
Originally Posted by Mazamin
JFFGRY706
Thanks.
There was no CD inside.
Jontay
Jul 22, 2021 08:23 AM
Bucketlist
Jan 24, 2015 01:27 PM
flektone
Sep 9, 2010 12:35 PM
