GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Old 12-15-14, 04:03 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Replaced battery now Power Windows don't work
Old 03-17-15, 07:10 AM
  #31
dazjjzlake
dazjjzlake's Avatar
Default my windows don't work
I thought it was fixed but the sequence was wrong. what is the correct sequence to make windows work.
Sincerely dazjjzlake dazjjz@jetbroadband.com
Old 03-17-15, 07:15 AM
  #32
mrblister
mrblister's Avatar
The re-set that was posted is correct. Try it again. Also make sure the lock out button is not engaged on the drivers master switch.
Old 03-17-15, 12:17 PM
  #33
Nothnghead
Nothnghead's Avatar
You might try rolling them up from half-way and holding for about a second or so once it's fully closed. That's what I've always done and had to do on my IS350.
Old 05-20-15, 02:42 PM
  #34
bSmart
bSmart's Avatar
Smile
Originally Posted by nmmuzykam
You need to lower each window one at a time ... You need to do this in the following order (on the switch on each actual door, not the master panel)...driver's, front passenger's, rear passenger's, rear driver's.
nmmuzykam, your suggestion worked for me as well. However only the rear windows started working through the main panel. For some reason the passenger window didn't work after trying your instructions twice.
So I decided to experiment and noticed the following:
  1. Lowered both driver and passenger windows at the same time time by pressing each window's own button down just to the first level (not all the way down to where it does auto-down).
  2. Raised both driver and passenger windows at the same time in the same manner as above.
The blinking lights on each button stopped blinking and issue fixed!
Old 02-06-16, 09:46 PM
  #35
Mikebrud
Mikebrud's Avatar
I disconnected the battery to my 2005 Lexus GX470, and the Windows wouldn't roll up or down. I did the reset and all the windows now work with the exception of the passenger window which is rolled down and won't roll up. The light on the window switch is blinking also. Any ideas?
Thanks
Old 02-07-16, 01:40 AM
  #36
mrblister
mrblister's Avatar
re_read post 31 and 33
edborges03
04-22-21 04:01 AM
akhosravi
07-26-19 07:10 AM
jmd_forest
RC - 1st Gen (2015-present)
06-10-19 03:42 PM
roccodog
02-17-19 03:41 PM
mbykow
10-06-17 09:35 AM
Quick Reply: Replaced battery now Power Windows don't work
