So... I had the hood open and when i pressed the gas it makes a short hissing noise of some sort... I'll try and get a video tomorrow... it only lasts for about 1-2 seconds not sure if its just induction noise...
It's the air rushing through the intake...to help make that 303 HP...
hopefully you guys are right and im just being paranoid.... also not sure how the DIG (direct injected gas) works... sometimes i hear a ticking and then it just goes away but i think i hear 2 ticking sounds probably just the engine and the DIG sounds out of sync maybe?
The high pressure fuel pump will make a ticking noise as it is driven by the right camshaft and also the second ticking noise will be coming from all the injectors. The valves may tick until oil warms up and the hydraulic lifters start to work. Another noise you may hear for a few seconds after a cold start, towards the front of the engine are the intake cam adjusters. There was a updated part for those to solve that issue.
