Swapping out projector lenses? Quest for sharper light cutoff..
Old 02-22-14, 08:50 AM
Skylar978
Skylar978's Avatar
Default Swapping out projector lenses? Quest for sharper light cutoff..
So, reading through some threads, gave me some inspiration to tackle this easy (so it seems) and fairly cheap mod. Since purchasing my 3gs, i have never been satisfied with the light output that our factory headlamps offer. I thought about a complete retrofit using different projectors (namely, some tsx(r)'s), but i thought i would tackle this the cheaper way first as from what I know, the lenses are what needs to be changed to benefit any real difference.
I was inspired by member beez43, who started a thread here: https://www.clublexus.com/forums/gs-...or-lenses.html
The problem with the thread, is that the link is broken and from what I read there is no disclosure of which lenses he bought, or pictures for that matter..
So, my question is, which lens should I try to swap to? More specifically, which lens would fit? The website that is linked on beez43's thread ,"theretrofitsource.com" seem to carry a 3" lens and a 2.5" lens. I am thinking about going with the 2.5" tsxr lens, but am not sure if it will be a direct swap?...
Please share your thoughts and information...
Old 02-22-14, 09:13 AM
SLOW4DR
SLOW4DR's Avatar
I feel the same way as you do about the light output. Unsure if the lens swap will do the trick. Surely it may help. I'd really like to do a tsx or s2k projector swap but I'm afraid the s2k won't fit because it's huge.
Old 02-22-14, 10:14 AM
BinaryJay
BinaryJay's Avatar
Good luck but for me this is the last sort of thing I have time to care about hehe.
Old 02-23-14, 07:59 AM
XxGoKoUxX
XxGoKoUxX's Avatar
From what I understand, people have used TSX-R lenses.... Beez43 isn't hard to contact, I believe, he's in Liberty, so contact Mike (Original Garage) from VSC (VipStyleCars) forums and see if he can help you get in contact with Beez.
Old 02-25-14, 09:09 AM
msequence
msequence's Avatar
TSX-R lenses are the best you can get for that sort of thing. If you are unhappy with our cutoff which isn't really that bad on the GS considering the work involved, TSX-R is your best bet as that's the choice of all retro fitters out there.
Cheers
Old 03-02-14, 09:55 AM
Skylar978
Skylar978's Avatar
Thanks for the replies everyone. I am ordering some tsxr lenses and will be sure to do a before and after of the cutoff difference (if any). Waiting for it to get a little warmer out before I tackle this!
Stay tuned!
Mrfouche
05-07-17 03:33 PM
iogs
08-14-11 02:28 AM
abounly
SC- 1st Gen (1992-2000)
09-27-10 08:38 AM
Miller
03-25-07 10:36 PM
BklynGS
Lighting
21
03-08-06 11:16 PM
Quick Reply: Swapping out projector lenses? Quest for sharper light cutoff..
