Both headlights out
Old 01-05-13, 02:58 PM
mydawgz
mydawgz's Avatar
Default Both headlights out
My 2006 GS 300 has needed some of the most random repairs. Both headlights are out. The left went out a few days ago and the right went out last night. Do I need bulbs or do I replace the entire lamp?? Lexus said it might be the ballast. I have zero experience with a ballast. My high beams are perfect. If the ballast is bad would the high beams work?? The idea of needing two of these is killing me. What is the best answer?
Old 01-05-13, 03:10 PM
AudioBob
AudioBob's Avatar
The high beams are a different bulb that does not require a ballast so that is why they still work. You are going to have to play process of elimination. Maybe start with bulbs since they are the cheapest to replace in comparison to the ballasts. Either that or take it to a mechanic/dealer.
Old 01-05-13, 04:39 PM
SNiiP3R
SNiiP3R's Avatar
Never heard of both ballasts going bad at the same time.... The easiest way to check is to install new bulbs or even better, if you know someone with 2006+ GS, just take their bulbs out and see if they'll work in your GS. You can also check your fuse box, maybe you have a burned fuse.
If the problem is indeed with your ballasts, then you should buy ballasts on ebay. It would be a lot cheaper than going to dealer.
Old 01-05-13, 06:05 PM
mydawgz
mydawgz's Avatar
Thank you. I am sure if it is the ballasts I will need to take it to a mechanic here in Tampa. I will try the bulbs first for sure. Are the bulbs fairly simple to change or is that a process too? We have had cars that were almost impossible to access the bulb. I am hoping these will not be too bad !! If anyone knows a good link that shows how to change them, please send it my way. Thanks again.
Old 01-05-13, 06:52 PM
SNiiP3R
SNiiP3R's Avatar
It's not too hard to change the bulbs. See how it is done here, https://www.clublexus.com/forums/gs-...fter-pics.html
Old 01-06-13, 12:43 AM
yrush
yrush's Avatar
Go with everyone recommendation. Change the bulbs first. Ballasts don't fail to often. I did have a older GS before where the fuse blew out. It would be a really odd if the left and right fuse blew out a day apart.
Old 01-06-13, 04:45 PM
jre002
jre002's Avatar
Bulbs both going out at the same time would be strange.
Check fuses first!
Old 01-06-13, 04:55 PM
ibidu1
ibidu1's Avatar
Check fuses first!
+1 then if you cant find anything I would grab a volt meter to the headlight plug to see if its getting power before throwing money at it.
DocVijay
CT 200h Model (2011-2017)
12
01-17-19 10:01 PM
Ledbetter
02-23-18 08:13 AM
amber1437
01-20-15 07:27 AM
Stun350
01-12-14 07:59 PM
LXMN
Lighting
12-17-06 08:14 PM
Quick Reply: Both headlights out
