06 lexus gs300 AWD headlights
I know there are a lot of post about headlights already but I can't find the exact problem I am having so looking for some advice. My headlights flicker and go out after only being on for a minute. It is high and low beams and both sides randomly so I can't switch bulbs to test. My passenger side low beam was replaced only a few months ago and I did replace with a phillips so it was not a cheap bulb. I have read if it's the ballast they would not come on at all but I am puzzled that it would be both sides high and low beams all at once. Any advice?
It's still probably bulbs and just bad luck, cheapest thing for you to do at this point is get a new pair of bulbs, any bulbs, cheap ones and try that first. You may also want to check if there is a single relay or fuse for the headlights and examine/replace it/them.
Wait high beams too? Definitely check loose/sketchy fuses/relays.
Yes high beams and low beams flicker and go out on both sides. I will take a look at fuses then go to bulbs from that point I guess that's my best route. Real bad luck for them to all go at once I guess
kayexalate
Nov 7, 2008 12:16 PM
