2008 GS460 NAV Bypass
Old 02-19-09, 06:23 AM
KrazeViper
KrazeViper's Avatar
Default 2008 GS460 NAV Bypass
I've been reading a lot about bypassing older versions and have read about updating ur system to bypass the 2008 version. Is there anyway to bypass this version at all. Does this in anyway violate anything in the contract by blocking this feature. And I read if I upgrade my NAV version it will let me bypass it all. Thanks for help.
Old 02-19-09, 08:35 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
08+ has 7.1 or later and i don't think the screen hack works anymore. if you want you will need to cut wire or get plug and play kits. diy has cut wire method, and if you want the plug and play kits, you can contact prestigious at chung@prestigioussociety.com a lot of us got our kits from them. you don't violate anything by using the kit coz' it's plug and play, you are not damaging the car and you can pull it out when you want
Old 02-19-09, 10:12 AM
JoshuaBLEU
JoshuaBLEU's Avatar
Default Cant reach Prestigious Society
I tried to contact 'Prestigious Society' via all of their three published e-mail addresses and all come back as undeliverable. Are they still in business?
UPDATE:
Finally reached Prestigious Society by phone. Knowledgeable guy. Will be ordering soon
Old 02-19-09, 10:17 AM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
huh?! i just emailed them yesterday and got a reply. i used chung@prestigioussociety.com
call them at (562) 644-3268, ask for chung, and tell them henry refers you
Old 03-01-14, 11:10 PM
49erGS460
49erGS460's Avatar
Hate to resurrect an old thread, but just to be sure.. Can the 2008 GS460 and beyond take advantage of the hybrid disc option to bypass the nav (get to the secret bypass screen with the menu, volume up, down, up down sequence?)
I've created and inserted the hybrid disc and it works with the updated maps (5.1/13.1, but can't access the bypass menu).
Tried removing the negative terminal on the battery both before I inserted the hybrid and after.. The second time, it gave me the common error with Japanese characters, had to eject, put in original disc and then the hybrid disc worked again.
Looks like Prestigous Society or wire cutting is our only option still?
Old 03-02-14, 07:09 AM
hanuman
hanuman's Avatar
I would be interested in this as well. I did the wire mod exactly like the instructions. All the wires matched up but no dice. For some reason the car was still getting the Vss signal.
So I am wondering if the colors changed again in the 08 models. It would be nice to get the wire color diagrams for the 08 model.
HybridHB
01-27-19 02:22 PM
ricnik
GX - 1st Gen (2003-2009)
01-07-15 11:35 AM
Zinda
12-29-08 11:42 AM
Joeb427
07-12-08 05:49 PM
2eyedocs
03-27-07 05:51 PM
Quick Reply: 2008 GS460 NAV Bypass
