TRAC ABS Module Pinout
Hey Guys, I am finishing up a customer build and need access to the wires that run to the ABS and Trac Module for the wheel speed sensors. I would prefer a pinout as I need the + and - sides of the wheel speed sensors. Any info? This is the last bit I need before we can start configuring the infinity on this GS300 turbo build. Will post some pics and info on this car as soon as I get it done.
Nobody has access to this info? I realize the manuals are copywriten and Lexus unlike Toyota locks down on their knowledge. But it takes a few min for someone who has the book or a pdf to tell me the wire color of the abs wheel speed sensors and maybe which pin they are in at the abs ecu. I need this for wiring in an infinity to a 99 gs300 and implementing the traction control. I really need this info, I have no access to it...
BillSkiner (08-19-21)
So far here's what I have: there are two shielded strands of wires from 2 different plugs on the ecu. Each has a red black and white wire then one has a yellow and the other has a green. Now I am familiar with the colors from working with our sc abs modules which we would wire for customer race cars (road racing). Now from there white is always a positive high side wire. Black is negative but never have I seen two blacks in a system. I'm guessing that's because it's a f/r difference? Problem is I don't know which is driven and what not. Still need that pinout...
iModerate
Since this is for a business you should invest into your company and purchase either an information service or purchase the wiring guides to help you with each job as you go, building up a library.
You can also get a 2-day subscription to Toyota's (& Lexus's) Service Bulletins, Repair Manuals, Wiring Diagrams, Technical Training, etc from Toyota @ $15.00. This may be the best option for you.
1999 Lexus 300/400 Wiring Guide on eBay @ $39.00 Shipped: http://www.ebay.com/itm/1999-Lexus-GS-300-400-Wiring-Diagram-Manual-NEW-GS300-GS400-Original-Electrical-/161516102957?hash=item259b1c252d&vxp=mtr
The following ABS Speed Sensor information may or may not help you. Use it at your own risk:
Front Right NEG - BRN > ECU PIN 13
Front Right POS - GRN/WHT > ECU PIN 14
Front LEFT NEG - BLU > ECU PIN 15
Front LEFT POS - PNK > ECU PIN 16
Rear Right NEG - ORG > ECU PIN 12
Rear Right POS - BLU/WHT > ECU PIN 11
Rear Left NEG - BRN/WHT **OR** RED/WHT > ECU PIN 20
Rear Left POS - BRN > ECU PIN 19
