2000 GS300 - OBD Code "P0446"
Old 02-02-15, 07:22 PM
femin
femin's Avatar
Default 2000 GS300 - OBD Code "P0446"
Hi all,
My engine light has been on for a while and today I used a wifi odb dongle ran diag and it gave me a code "P0446 - Evaporative Emission System Vent Control Circuit",
After calling couple shops they suspect its the evap cannister vent valve.
1) is that the samething as Vacuum Switching Valve (VSV) ?
2) I would like to do it myself and wonder if any of you have instructions that could help me on this?
Thanks all!
Old 02-02-15, 08:07 PM
lexo98
lexo98's Avatar
Search the P0466 code and gas cap
Old 02-02-15, 09:03 PM
SC4Paulo
SC4Paulo's Avatar
p0446 with no other code is a closed CCV in other words canister closed valve is clogged per factory service manual.
and for your information VSV ie. Vacuum switching valve is on the driver side next to the intake manifold on GS400, id have too look at a diagram to find gs300 vsv. The CCV is the valve off of the charcoal canister in the rear of the vehicle i believe, never looked at my charcoal canister so don't know to be exact.
Old 02-02-15, 09:18 PM
Mr Jokster
Mr Jokster's Avatar
Only because I've posted it a ton of times am I able to post it again. Yea the valve is on the canister, its available here (log in to sewell with your Club Lexus screen name and get a $25 discount):
http://lexus.sewellparts.com/oem-cat...S300-2000.html
Its #77740N on the below picture on the top right.
Also available on ebay for $28 bucks:
http://www.ebay.com/itm/Vacuum-Switching-Valve-Dorman-911-602-/271721458387?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f43dc6ad3&vxp=mtr
Old 02-09-15, 06:20 AM
femin
femin's Avatar
That's great information!! thanks guys i'm going to try to replace it soon and see if it fix. i'll report back.
Old 08-11-22, 10:33 AM
naluloa
naluloa's Avatar
Old 08-11-22, 10:45 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
Originally Posted by naluloa
Assume you have the same problem and wonder what the resolution was? If so a nice way of bumping might be to do something like this (although the OP hasn’t been on since 2019):
@femin following up from your post above, did you get a resolution? Thanks
Old 08-11-22, 11:01 AM
CPTSOLO
CPTSOLO's Avatar
Depending on how many miles the car has, more likely the Evap Cannister is full. The solenoid is far less likely to fail.
The Evap Cannister sits on top of the gas tank, difficult to access and replace. It may save time and money to buy the whole canister assembly with the VSV and swap it in. New canister from dealer may be $600.-800; an used one may be $100 -200..
Old 08-11-22, 03:50 PM
Frankn
Frankn's Avatar
I had a kinked purge line behind the intake manifold by the firewall drivers side, check that line and follow it where it goes down from the valves
RayN
RX - 1st Gen (1999-2003)
01-19-15 07:36 PM
robo
01-28-13 10:05 PM
99a6q
GS - 1st Gen (1993-1997)
02-28-09 07:49 PM
Quick Reply: 2000 GS300 - OBD Code "P0446"
