vvt actuator
Old Aug 11, 2022 | 12:26 PM
Hurr's Avatar
Hurr
2nd gear
Default vvt actuator
hey does someone know what the part circled in red is called? the one circled in green is the solenoid which is leaking and needs replacement, but I was wondering if the one circled in red could be causing the leaks too
Old Aug 11, 2022 | 12:27 PM
Hurr's Avatar
Hurr
2nd gear
Old Aug 12, 2022 | 08:49 AM
captainva's Avatar
captainva
The part in red is called the #1 oil pipe and has 2 non re-useable washers if you take it off and you should also replace the filter contained at the end of the bolt. That provides the oil for the oil control valve in green above.
jfoster31
CT 200h Model (2011-2017)
Jan 3, 2023 12:30 PM
e43Guy
Oct 14, 2004 12:36 PM
silkiechic
Jul 30, 2004 08:58 PM
