check engine light
Old 04-28-14, 08:08 AM
crangs400
crangs400's Avatar
Default check engine light
have a po441 code car loses all power when you acclerate need help to fix problem please mechanic says charcoal canister wouldnt cause the acceleration problem
Old 04-28-14, 08:41 AM
bonesnj0
bonesnj0's Avatar
Check the vsv by the canister take 9v battery attach to the 2 terminals listen for click.
find valve on Ebay.
Code=: Bad vacuum switch Broken or damaged EVAP line or canister Open in PCM purge command circuit Open or short in Voltage feed circuit to Purge Solenoid Faulty purge solenoid Restriction in EVAP solenoid, line or canister Corrosion or resistance in purge connector Bad PCM
Old 04-28-14, 08:59 AM
tereck
tereck's Avatar
Check the hoses right next to the evap service port. Before and after. Cracked or loose hoses will cause this code and check for the mention above
Old 04-28-14, 07:35 PM
ttaylor993
ttaylor993's Avatar
Mechanic's right. Bad canister will cause the P0441 code but will have no effect on acceleration. P0441 is an emission code, not performance.
Old 05-05-14, 12:43 PM
crangs400
crangs400's Avatar
ok thanks for the help
Old 05-05-14, 01:31 PM
wbmx1981
wbmx1981's Avatar
Lose of power could be low transmission fluid.
campoida
15
05-07-09 01:36 PM
asadchinoy
11-17-05 07:47 AM
SDJZZ31
Performance & Maintenance
06-17-05 01:18 PM
GOLDSc300
Maintenance
12-25-03 07:11 PM
Quick Reply: check engine light
