Bad water pump or pulley?
Old 05-07-13, 08:30 AM
PinaQkoNga
PinaQkoNga's Avatar
Default Bad water pump or pulley?
Wassup CL!
My '99 GS3 has 175k. I'm about to finally get my seals, gaskets, & belt(no cracks but replacing anyway) changed out. I replaced the timing/pump at 133k but with NON-OEM parts. There's a "washing machine" sound coming from the water pump or the pulley. Should I swap it out for a oem one? Sounds like a bad pump or pulley? There's some oil leaks due to bad seals so there's oil on the water pump too. None seems to be on the serpentine belt. Thanks! -Rene-
Old 05-07-13, 08:56 AM
AZTurbo
AZTurbo's Avatar
I guess any water pump can fail after 40k miles. Have you inspected the pump itself to see if the water is cominig from there? I think it is ok to use non oem parts, but I would suggest only Aisin if you are not buying Toyota OEM.
Old 05-07-13, 09:02 AM
Blanco
Blanco's Avatar
I would suggest going with stock pump. Probably a bearing going bad. I'm about to do my 2nd belt and pump. This time around my mechanic is telling me I should replace ALL pulleys, tensioners, and belts. I'm at 208K, and plan on keeping it a while longer.
My A/C compressor is already making bearing noises. I found a DIY here to replace just the bearing, and where to get it, since Lexus won't sell just the bearing.
Old 05-07-13, 03:10 PM
PinaQkoNga
PinaQkoNga's Avatar
Thanks for the 411. I'm going oem.
vonhamrick
03-19-18 03:06 PM
BY5260
01-09-17 09:57 PM
Bocatrip
07-04-16 04:10 PM
MarcoP
01-30-14 08:34 PM
dave95sc
Performance & Maintenance
10-11-04 05:30 AM
Quick Reply: Bad water pump or pulley?
