Replaced water pump now putting it back together
I suspect I may get really questioned but I'm ready for that. During a recall for my 2005 ES330, the service department showed me a leak from the water pump. I believe it's the original water pump but I have had the timing belt changed before.
For whatever reason (maybe a head injury I forgot about or the high cost) I decided to do this repair myself. I'm fairly comfortable working on things and I have about every tool ever made. This car is kind of an "extra" at our house so I figured that time wasn't a huge issue. I've now got the car unassembled (laid parts out on a table as I removed them and took a lot of photos).
As I prepare to reinstall the parts, I'm starting to get some real anxiety. I don't want to go through all the work of putting it back together and finding it won't start. Oh, and also, the w/p, t-belt came with new seals for the camshafts and crankshaft. How difficult are they to replace when the engine is basically torn down for water pump replacement. Again, I think the original seals are in the car and I can't say for certain they are leaking but......
So back to my anxiety; I'm confident in putting all the parts back where they go. What I'm nervous about is making sure the timing is right. I didn't worry to much about the position of the crankshaft as I didn't think it would move during this repair. I had no problem getting the bolt out and the pulley removed. When I looked at the camshafts, I believe the previous mechanic marked thing with red nail polish or something. The sprockets were marked and so was the bracket behind the timing belt. They were at about the 2:00 position. I did notice as I was trying to remove the camshaft pulleys (back one was almost impossible but I got it). The pulley would rotate as I put force onto them. They didn't turn freely. It was almost as if they had a notch(or hill and valley) or something and they'd stop in those positions as they turned (not sure how to better describe that).
So now I'm worried that I may have messed up something with the timing. I'm ready to put it back together, planned to slip the belt onto the crankshaft and then line the red marks up on the camshafts. I know there are notches in the camshaft pulleys so they pulley must be put on in the exact same spot as it was removed. So is this going to work or do I need to do something more to insure I don't get sick when I try to start it and it won't start? After I've got it running again, I need to change at least one of the valve cover gaskets as it seems to be leaking. I don't want to tackle that until I hear the motor run after my last repair. If some of this doesn't make sense, I may have some photos to better explain it. I'm hoping you're able to just visualize it. I do appreciate any help you can offer.
Firstly not to be rude but have you ever heard of paragraphs? A wall of text is not exactly easy to read. Watch this video along with maybe a couple more on seal replacements, there are several methods of doing it including a special seal remover for the camshafts
BY5260 (01-10-17)
I suspect I may get really questioned but I'm ready for that. During a recall for my 2005 ES330, the service department showed me a leak from the water pump. I believe it's the original water pump but I have had the timing belt changed before. For whatever reason (maybe a head injury I forgot about or the high cost) I decided to do this repair myself. I'm fairly comfortable working on things and I have about every tool ever made. This car is kind of an "extra" at our house so I figured that time wasn't a huge issue. I've now got the car unassembled (laid parts out on a table as I removed them and took a lot of photos). As I prepare to reinstall the parts, I'm starting to get some real anxiety. I don't want to go through all the work of putting it back together and finding it won't start.
So back to my anxiety; I'm confident in putting all the parts back where they go. What I'm nervous about is making sure the timing is right. I didn't worry to much about the position of the crankshaft as I didn't think it would move during this repair. I had no problem getting the bolt out and the pulley removed. When I looked at the camshafts, I believe the previous mechanic marked thing with red nail polish or something. The sprockets were marked and so was the bracket behind the timing belt. They were at about the 2:00 position. I did notice as I was trying to remove the camshaft pulleys (back one was almost impossible but I got it). The pulley would rotate as I put force onto them. They didn't turn freely. It was almost as if they had a notch(or hill and valley) or something and they'd stop in those positions as they turned (not sure how to better describe that). So now I'm worried that I may have messed up something with the timing. I'm ready to put it back together, planned to slip the belt onto the crankshaft and then line the red marks up on the camshafts. I know there are notches in the camshaft pulleys so they pulley must be put on in the exact same spot as it was removed. So is this going to work or do I need to do something more to insure I don't get sick when I try to start it and it won't start?
Dude, .... paragraphs.
BY5260 (01-10-17)
usermel
07-10-19 02:18 PM
Superfast1
13
07-15-15 02:46 AM
