1999 Gs300 Aftermarket HID Headlights
wass up everyone, I own a 99 GS300 that has an aftermarket HID headlights kit installed by previous owner. Although they look super clean and useful at night, I want to take them off. That said what are my options if I take the kit off will I go back to stock headlights? how does that work? Or do I put on a less brighter kit, where do I go? Suggestions please.
Thanks
Thanks
Usually aftermarket HID kits are a simple plug & play setup. So you should be able to return to stock bulbs after you unplug the aftermarket lights. It all depends what you want to achieve...
It looks like you have an aftermarket HID light kit in a stock head light housings. If you had some HID head light housings then the light would be on the road where you need it. Do you have any close up pics of your head lights?
If you want bulbs that are brighter than the stock 9006 but not as bright as HID's. I recommend trying a set of HIR bulbs. Many have used them with great results. Do a search for HIR bulbs to find the right #'s to buy. I'm not sure if its the 9011's or the 9012's that work best to relplace the stock 9006 bulbs.
Amazon or Ebay, I'm sure there are lots of other online sources as well.
Check out this website.
http://hirheadlights.com/
Install HIR bulbs. I did this on my car about a month ago and they are great! Much more light vs. halogen and it will be better than that horrible kit because the light will go where it suppose to. Look on amazon. I bought my bulbs there. 9012 IIRC...
I'm running the same bulb and love them. It gives better light than our 2004 Cadillac SRX with HID's that have dimed over the years. When I pulled the old 9006 bulbs out I just drew a rough template of what to trim off with a pencil and used wire cutters to trim and see if it fit, took 10 min. I might upgrade to HID kit in the future but am very satisfied with the halogens I have.
Muti007
GX - 1st Gen (2004-2009)
23
03-22-12 03:39 PM
nar8ta
08-07-08 02:16 AM
