Cleaning throttle body from the inside
Old 08-01-12, 11:46 AM
LexGs300D
LexGs300D's Avatar
Default Cleaning throttle body from the inside
Hey guys can anyone pls tell me what stuff i should use to clean the inside of my 98 gs300 throttle body? My buddy told me that break cleaner/carburator cleaner is fine? Do i just spray it inside and wipe or let it dry?? Reason why im doing this is my idle not as used to so i figured all that oil and grease build up is some how affecting my idle control arm.
Thank you all in advance for any anwsers i might get to this Post!
Old 08-01-12, 12:01 PM
vwynn
vwynn's Avatar
Carb cleaner works well. Spray and wipe. Or spray on towel and wipe.
For more info on this run a search on "cleaning throttle body" on the 2GS forum exclusively.
Old 08-01-12, 12:06 PM
LexGs300D
LexGs300D's Avatar
Thank u alot for the info. Can it also be used to clean the contacts ( connectors ) on sensors? And can it clean the grease off of my engine head/block? Just wanna do a little bit of cleaning in my car today
Old 08-01-12, 12:25 PM
vwynn
vwynn's Avatar
NOooooooooooooooo lol dont use it on contacts or sensors. its HIGHLY strong.
if ur going to use it to clean the MAF use MAF cleaner. Cleaning contacts use Electrical Contact Cleaner lol. Use the specially formulated bottles for each task.
for engine bay u can use carb but they sell engine block cleaner. if ur engine block is dirty than youre probably leaking somewhere. find out!
Old 08-01-12, 12:32 PM
Debonair
iModerate
Debonair's Avatar
The best product for cleaning the Throttle Body is Throttle Body Cleaner. It should be available at all auto part stores. Get a can of MAF cleaner too while there and get your MAF done.
Old 08-01-12, 02:05 PM
LexGs300D
LexGs300D's Avatar
Thank you guys very much!! This is useful information for me but i got another dumb question ... What does MAF stand for? Manifold??
Old 08-01-12, 02:34 PM
Klovely341
Klovely341's Avatar
I have a 2002 ES 300 and my car starts but idles out after a few seconds. It is a drive-by-wire throttle body. I was wondering if anybody had any idea on how to fix this issue or am I stuck paying 913$ in parts?
Old 08-01-12, 02:40 PM
Debonair
iModerate
Debonair's Avatar
MAF = Mass Airflow Sensor
the DIY is HERE.
Old 08-01-12, 04:52 PM
LexGs300D
LexGs300D's Avatar
lol once again thank you very much, and thank you whoever started this site
Old 08-01-12, 05:50 PM
kit cat
kit cat's Avatar
wait, cleaning TB usually means cleaning the...outside?
Old 08-02-12, 12:21 PM
wise2k
wise2k's Avatar
MAF = Mass-Air-Flow (sensor)
Old 08-02-12, 01:04 PM
Debonair
iModerate
Debonair's Avatar
I would not say usually but I guess in certain circumstances it could.
Old 08-02-12, 04:53 PM
LexGs300D
LexGs300D's Avatar
Thanx guys, did it all yesterday, the throttle body is sparkling clean. Had a dirt build up of about 1 or 2 mm right in front of the inside flap. My idle was 500 rpm over the usual ( im guessing since there was no more dirt build up there ) but today car run perfectly and the ilde is back to normal. Ill post pictures next time for everyone else doing same kind of work.
MValentine
02-04-13 07:41 PM
bigblack06
02-25-12 12:53 AM
matrixgts
Performance & Maintenance
11-09-08 05:20 AM
Stage3
Maintenance
01-08-08 07:05 PM
tmf2004
Performance
08-24-05 07:31 PM
Quick Reply: Cleaning throttle body from the inside
