GS4 130K Safe to switch to Synthetic?
I recently purchased a 2000 GS400. I would like to start using Amsoil in it, but i'm concerned because the mileage is high. Any thoughts are appreciated.
depends but it shouldnt be bad.. if it does leak then just fix it.
Obviously if it starts leaking cuz of the switch then it woulda leaked over time anyways. Better fix it now than later.
http://www.youtube.com/watch?v=1-ZpHr5l0U0
go on lexus.com and input your VIN in the vehicle thing to see pass records from Lexus.. it gives you an idea at least.
https://secure.drivers.lexus.com/lex...-lexus/home.do
That's totally incorrect.
It's a leftover old wives tale from the days when Synthetic oils were a new product and being put in ancient cars.
Let me put it this way, if you car is being held together by sludge the Synthetic Oil may, over time, break down enough of the sludge to expose the gaskets to fresh oil. If your gaskets are ****ty cork like in the old American cars with large part tolerances, then it'll probably leak.
On your Lexus 130k miles and the engine isn't even at it's halfway point. The tolerances are all much closer, and the gaskets all started out as a higher quality material.
The only thing Synthetic will do is flow easier and quicker in the mornings. Which is especially important during these cold winter months. This will reduce some engine wear at start-up.
Also, on teh subject of sludge. If you think your car's engine may have some sludge buildup you want to clean it out slowly, not all at once.
A way to do this (like my old Tacoma was) is to use Synthetic oil plus a single quart of diesel oil every oil change. And change the filter every 1500 miles. Diesel oil has alot more detergents than regular oil, and will break down the sludge. Only one quart because you want to do it slowly.
My synthetic oil experience
I started using synth in my GS400 at 127,000KM when I bought the car - now 160,000KM - No problems.
I switched my 91 Sunbird to synth at 395,000KM - No problems
I switched my 2004 Malibu to synth at 130,000Km - No problems
I switched my 90 Cressida at 114,000 KM - No problems
I think you're safe
I think you're safe
2001 gs430...195,000 miles....1998 es300 155,000 miles...2001 rx300 245,000 miles...all use synthetic oil...and not one leaks a drop...can back that up with my previous cars...1994 ls400...248,000 miles no oil leaks....2001 gs300...207,000 no oil leaks...2000 ls400...62000 lol no oil leaks...
i've been using synthetic on my truck and 2gs since day 1.
2004 v6 tundra. w/ 110K. still runs like brand new! :thumb up:
same with the 2003 GS300 w/ 55K. :thumb up:
jus the suspension woes of lowered 2GS...
however, the woman's 2IS... always been serviced by Lexus... so thats been taking what they normally give. still good. it just has the trembles from time to time.
MoogieBoogie
Performance & Maintenance
10-01-03 03:55 PM
