How to Reset VSC light ??
Old 04-11-11, 06:33 AM
bugsys
bugsys's Avatar
Question How to Reset VSC light ??
My VSC and VSC Off lights have been on ever since I bought the car. I replaced the ABS/VSC control module but the lights are still on. I'd like to reset the lights and see if they stay off (module replacement worked) or if they come back on (something else still needs to be fixed); however, I have no clue how to reset these lights.
I've heard it's possible ... anybody know the trick?
Old 04-11-11, 07:04 AM
2jzgttegs
2jzgttegs's Avatar
This happended to me aslo, If you look under the hood theres a gray diagnostic box. Use a paper clip & jump E1 to Tc then put the keys in the ignition, then turn keys to ACC then step on the brake 5-8 times rapidly and it should come off then beep. After that take the pin out start vehicle & drive it, to make sure everything is back to normal.
Old 04-11-11, 02:23 PM
porn-adkt
porn-adkt's Avatar
ABS/VSC Module? the ECU? did you run a Diag? Usually the 2nd Gen ABS/VSC problems have nothing to do with the ECU..I doubt jumping the E1/Tc terminals on port DCL1 will solve your problems..
Old 04-12-11, 08:29 AM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
If you replaced the ecu the system will need to be reset by the dealer or a lexus/snapon diag/computer tool. You can try the paper clip trick but I guarantee you that the lights will pop on.
Old 04-15-11, 06:48 AM
bugsys
bugsys's Avatar
No ... I never replaced the ECU ... I replaced the ABS/VSC module. Just trying to reset the VSC lights to see whether or not it was the ABS/VSC module that was bad. Thanks for the jumper trick ... we'll see.
Old 04-18-11, 07:39 AM
bugsys
bugsys's Avatar
UPDATE: I jumpered the diagnostics ports, turned the key to the ACC position, and rapidly pumped the brakes until the lights went out. Then the VSC light started flashing while the VSC OFF light remained off. The VSC light flashed 4 times, stopped, then flashed 3 times. It continued this sequence until I turned the key off and disconnected the jumper.
I assume this is flashing an error code at me. Any ideas what this means?
Old 06-01-11, 07:09 AM
starfyrels
starfyrels's Avatar
Probably the flux core capacitor hi-lo converter.
Old 04-14-16, 08:53 AM
Lakersfan
Lakersfan's Avatar
I was gonna suggest the up, down, up, down, left, right, left, right, a, b, select method
Old 04-14-16, 09:56 AM
sakataj
sakataj's Avatar
nice bump on a 5 year old post for nonsense... TO BAD though the Konami Code is up, up, down, down, left, right, left, right, B, A and not the mess you posted
Lawrence S
02-21-24 06:54 AM
mcysr
01-12-24 07:09 AM
redliner8
01-04-23 01:39 PM
Sublime69
11-21-12 03:30 PM
sc430blue
01-26-05 08:42 PM
Quick Reply: How to Reset VSC light ??
