CEL Code: P0018
Old 10-04-10, 11:55 PM
Blk04GS430
Blk04GS430's Avatar
Question CEL Code: P0018
Hi guys,
I just got this CEL code: P0018 yesterday while driving home after getting my spark plugs, thermostat, coolant drain/refill, both radiator hoses, timing belt, water pump, idler bearing, tensioner bearing and accessory/serpentine belt done. Im not sure if it is related to the work that was done or just a coincidence. The CEL light didnt come on right away after the work was done. It came on about 50 miles & a couple of trips later that day right after I stopped to get some gas. The CEL, VSC and VSC OFF lights came on at the same time. I 1st thought it was related to the gas cap because it wasnt in limp mode and it was driving at 55-65mph ok.
I went to autozone the next day and their code reader gave me only 1 code even though I had CEL, VSC and VSC OFF lights on. The code reader gave me the following information:
P0018
Crankshaft position- camshaft position correlation
Bank 2 sensor "A"
Probable cause
1- Mechanical valve timing condition
2- Camshaft actuator condition
Does anyone know anything about this specific CEL code: P0018 and what does it affect specifically mechanically/performance-wise? What needs to be done to fix the issue? I tried searching the forums for this CEL code: P0018 but I couldn't find anything. Any information would be greatly appreciated. Thanks in advance for your time and help.
Old 10-18-20, 09:27 AM
Lexus084
10th Gear
Lexus084's Avatar
Default Same problem.
Originally Posted by Blk04GS430
Hi guys,
P0018
Bank 2 sensor "A"
Probable cause
I am having the same code on ls430 2004.
Old 01-25-22, 03:39 AM
Lexus084
10th Gear
Lexus084's Avatar
Default I have the same code. P0018
Same here somtimes it goes by itself somtimes it pops on.
The car starts from the 1st attempt but somtimes it take 2 - 3 seconds to start.
No other issues i have faced in car power or when takin off. The rest works fine...
So i dono is it a failure sensor or need to do the adjustment or camshaft require seals or i dono wot else...
My car model is lexus ls430 2004 ultra luxury korean imported.
Old 01-26-22, 08:26 AM
TrueGS300
TrueGS300's Avatar
Get it back to the shop that did the work ASAP. It is a code for timing issues and you just had the timing system worked on. I'd say it's certainly related.
QLex300 (01-26-22)
Old 01-26-22, 08:42 AM
Lexus084
10th Gear
Lexus084's Avatar
Default No jobs
I didn't take the car to a mechanic.... Or havent done any kind of works..., i had this code since i bought the car...
As i said there is no loss of power, no hasitate,
the car starts from the first attempt but somtimes it takes 1 - 2 seconds.
The codes disappears by itself somtimes,
Somtimes come bk
ahornick
10-11-23 08:30 PM
Jetmtx
09-19-21 08:28 AM
cdiewater
Performance
08-02-16 10:44 AM
adamyansam
03-14-11 07:48 AM
waxman
02-02-09 09:45 PM
Quick Reply: CEL Code: P0018
