Question about GS/IS 300 Exhaust Manifold
Hello every one,
I have a 2005 Lexus GS300 and I have clogged catalytic converters and as I don't have much money to replace them I was looking into aftermarket cat-less exhaust manifold. The only option I could find was for a IS300 (I will link to amazon below) and I know that they have the same engine. I was wondering if you guys know if the IS300 exhaust manifold is the same for a gs300? The mounting point to the mid-pipe looks the same. My only concern is the length of it, although it looks identical.
If you guys know any cheap alternatives feel free to let me know. I would poke holes in the cat if I could reach them. My only other option is to try to unclog them with chemicals.
Thank you
Amazon -
Thank you
Amazon -
Yes the cheap ebay ones for the IS will fit fine. Its the mid pipe after the catted manifold that is shorter on the IS. I was just asking about this too. However someone mentioned that the o2 bungs are wrong on some of them.
Check this one out. Same thing for way cheaper
https://www.ebay.com/itm/Stainless-S...0/282526054710
Judging by the Bungs being where they are in the pics, it shouldnt run into anything
sorry I didnt quote you when replying to your post.
No I haven't got one yet, still thinking about it. But this is the one a member on here has installed right now and sent the link for me. So it has been verified to fit.
https://www.ebay.com/itm/3-2-COATED-STAINLESS-RACING-HEADER-EXHAUST-MANIFOLD-FOR-01-05-LEXUS-IS300-JCE10/273504778829?fits=Model%3AIS300&epid=2295798159&hash=item3fae27ba4d:g:3T0AAOSwn01cL1Is:rk:27f:0
As I said in the first one I sent the link for, the o2 bungs are in the same places. So if you like the polished look, I wouldn't hesitate
I have those IS300 headers in the link above installed in my 2004 GS300. The black paint comes off fast after a few heat cycles but just reuse your OEM metal exhaust manifold gasket that sits on the cylinder head because the gasket included does not compare in quality to the OEM one.
Here is how it looks:
Attachment 504389
Attachment 504390
Attachment 504389
Attachment 504390
This will bolt right up to the factory 01-05 GS300 midpipe and catback exhaust with no modification needed but the lower exhaust bracket bolted to the transmission is no longer needed.
The flanges on my oem midpipe were not in the best condition and it also had pinhole leaks around the last bank 2 o2 sensor flange on that mid pipe so I bought a Megan Racing mid pipe later on which still connected right up to these IS300 headers and factory cat-back exhaust.
Yes, I reused the metal OEM exhaust gasket and no leaks but I cleaned the metal gasket very good with some brake cleaner and made sure the cylinder head was clean too. I do not really notice a difference in temperature but headers and catalytic converters can get extremely hot on any car so you will be fine. They also make header wrap which does work to keep temps down and I used that on my Supra until I removed it and found out it started to rust in some areas which I do not use that wrap on my exhaust pipes anymore.
iirc the header does come with 2 small o2 spacers but they were a straight style and I like the 90 degree ones much better. Just make sure when you install the 90 degree ones, have them angled so water does not build-up and stay stored in that spacer. You can see how I have one of the spacers angled in my pic so any build-up of water can escape back into the header.
Golo1949 (07-04-22)
