Transmission Fluid Leak
Old 12-23-12, 05:08 PM
heyray42
heyray42's Avatar
Default Transmission Fluid Leak
I have a 1995 GS300 with 177,000 miles that has a transmission fluid leak. Is it common with this kind of mileage? If so, what is the remedy?
Old 12-25-12, 04:57 PM
lkmljp12
lkmljp12's Avatar
Most likely the gasket is dried up or the "O" ring is to dried, or the plug is bad.
This is what i recommend... clean the bottom of the transmission, and figure out where is it leaking from... if is leaking from the pan, i recommend to replace the gasket, filter, and add new trans fluid.
If u got it serviced by someone not so long ago, is most likely they used a bad gasket, or failed to placed it correctly...
Try to use: " Beck/Arnley Transmission FIlter Kit" and get the fluids from your toyota dealer.. do not use those generic fluids from autozone... the dealer fluid is pretty cheap.. $5 to $6 a quart..
To remove the pan, get all the screws around the pan, and you might have to loosen the trans dip stick holder.
Old 01-08-13, 01:10 PM
heyray42
heyray42's Avatar
Thanks for all your help. It turns out that I had a broken hose.
Gcuarino
04-15-19 04:39 PM
jerry400
12-21-16 12:57 AM
UGAALF
05-13-16 10:18 PM
lserlohn
RX - 1st Gen (1999-2003)
01-29-12 11:31 AM
Gdfela400
06-14-11 01:19 PM
Quick Reply: Transmission Fluid Leak
