ABS Light problems!!
Old 02-04-11, 11:20 AM
henry89trd
henry89trd's Avatar
Default ABS Light problems!!
Hey guys I have noticed that my abs light on my dash comes on once in a while. not all the time. I have the brakes checked and had to put new pads on the rear brakes, but everything seems to be OK. Has anybody had this same problem? Do any of you have an idea as to what I can do or where I can start to solve this problem??
Old 02-04-11, 06:17 PM
deknick
deknick's Avatar
do any other lights come on?
Old 02-09-11, 08:23 PM
henry89trd
henry89trd's Avatar
nope, no other lights come on.
Old 02-20-11, 08:51 PM
deknick
deknick's Avatar
chances are that it's a ABS sensor, check the connections, and if need be, get a shop to scan it. i'm putting my money on an ABS sensor is the problem, as long as no other lights are on
Old 06-18-11, 11:59 AM
jdmgs300
jdmgs300's Avatar
i have the same issue just started yesterday but my trac off light will also come one 3 seconds after the abs light i might check the sensor and source the issue
Old 06-18-11, 11:31 PM
m1k3yg
m1k3yg's Avatar
I know this has nothing to do with the abs light, but for the past couple days a light on my cluster has been going on and off, the light is a picture of the carr with lines coming from the back, any ideas?
Old 06-20-11, 12:08 AM
deknick
deknick's Avatar
m1k3yg, that would be you have a rear bulb burnt out. if it's neither the marker, brake, signal or reverse light that are burnt out or has a bad connection, then the 3rd brake light with LED's in them, might be crappin out
Old 06-20-11, 12:09 AM
deknick
deknick's Avatar
does the ebrake light come on as well?
Old 04-21-12, 04:34 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Guys,
Where is the sensor located? I replaced my radiator today and all of a sudden, my abs light is on. I bet some coolant may have gotten the sensor wet. Hopefully it dries. I will create a new thread, but does anyone have any insight on this?
thanks,
Bryan
Old 04-21-12, 10:29 PM
MikeC7909
MikeC7909's Avatar
Originally Posted by Wald GS
Guys,
thanks,
Bryan
The ABS (Anti-lock brake system) sensor(s) are located on your front steering knuckles and rear knuckles. If you google image "abs sensor on spindle" or something like that you'll get the general idea. As for why your light is on after a simple radiator replacement..that's a since they don't contact each other at all. Maybe coincidence or bad luck that your abs sensors went bad when you swapped the radiator.
Old 04-21-12, 10:32 PM
MikeC7909
MikeC7909's Avatar
Also, if the light don't go away anytime soon, then you should take it to a good mechanic/shop to have them pin point which sensor it is. Rather than guessing which of the 4 sensor it is. I personally don't know how to test them yourself. Maybe voltmeter? =P
Old 04-22-12, 01:45 AM
Wald GS
Wald GS's Avatar
Light went away after a few hours. Must of been the angle of the car while it was jacked up for both a oil change and radiator change.
tariqRX350
01-06-16 01:13 PM
sik96ls400
12-04-09 03:19 PM
llbouch
RX - 1st Gen (1999-2003)
03-21-07 05:34 PM
dannyypk
Maintenance
10-31-04 09:14 PM
illson_2k
05-30-03 01:17 AM
Quick Reply: ABS Light problems!!
