how to take off shifter and woodgrain
Old 02-12-05, 09:39 AM
gompka
gompka's Avatar
Default how to take off shifter and woodgrain
How do you take off the shifter and the wood grain around it? I have the rear of the center console loose but where is the front attached?
Old 02-12-05, 09:43 AM
johnee78
johnee78's Avatar
You must first remove the ashtray and then on the base of the shifter there is a plastic cover that slides down..When you slide it down there are 2 screws that you remove and the shifter comes right off..Once this is done you pry up the back of the plate and also lift it from the front were you removed the ashtray.. Hope this helps..
Old 02-13-05, 10:02 AM
gompka
gompka's Avatar
lolz thanks that worked out great.... wonder how long it would have taken me to figure that out on my own LOL
Old 02-16-05, 09:11 PM
gompka
gompka's Avatar
well vinyl is a pain in the *** to work with.... but i got it done with the help of a trusty heat gun.... few tiny tiny bubbles near ect switch but other than that it came out nice. Its black ash vinyl, i think it looks better than stock brown.
Old 02-16-05, 09:24 PM
turbogs300
turbogs300's Avatar
Looks good! Now go buff out the plastic around the shifter Did you do the ashtray and door switches to match? I've been thinking about doing all mine in Blue CF. Post a pic of it in the car!
Old 02-16-05, 09:27 PM
gompka
gompka's Avatar
lol i know the plastic piece pops out so i'll do it when i get the chance. for now i did the shifter surround. Next up is the ashtray and my dashkit and then the door switches. Its hard not to get bubbles gotta go real slow and use alot of heat but too much messes it up.. bah
Old 03-08-05, 10:02 AM
CTgs300
CTgs300's Avatar
was your wood chipped or broken before you did this?. also where did you pick the vinal up
Old 03-08-05, 10:36 AM
gompka
gompka's Avatar
it was broken off all the way to the aluminum underneath. Vinyl can be bought at partsexpress.com
Old 03-08-05, 12:25 PM
turbogs300
turbogs300's Avatar
Cool
I've seen different vinyls on EBay
Old 03-08-05, 12:44 PM
turbogs300
turbogs300's Avatar
Cool
Wow, I had mentioned partsexpress, however, I edited it out because I didn't think the speaker cover vinyl was flexible enough.
Old 03-08-05, 01:32 PM
gompka
gompka's Avatar
it is after some help from the trusty heatgun
Old 03-08-05, 03:25 PM
CTgs300
CTgs300's Avatar
did you try polishing the aluminum? I may do that mine is all chipped off closer to the cupholder
Old 03-08-05, 03:47 PM
GenOneGS
GenOneGS's Avatar
I thought about polishing that aluminum / stainless but I think the sun would hit it and be blinding.
Old 03-08-05, 03:49 PM
turbogs300
turbogs300's Avatar
Cool
I know you can buy a flexible adhesive backed sheet of chrome and possibly a brushed one as well. Guess it all depends on your theme.
Old 03-08-05, 04:00 PM
gompka
gompka's Avatar
if you can get the wood grain off the aluminum without scratching it..... good luck with that though as its glued down well
Quick Reply: how to take off shifter and woodgrain
