Car won't start after cleaning the throttle body
I went to clean my wife's throttle body out with brake cleaner and I think I sprayed too much into the throttle body now the car won't start. It makes a small clicking/grinding noise when I try to start it. What have I done?
u destroyed it it with the brake cleaner, thats y u should always get the cleaner made for it, take it out and go get a throttle body cleaner and clean it again but dont soak it, or better get the Air Mass meter cleaner and clean it with that which is more safer. and let it dry real good and keep ur fingers crossed that it will start. good luck.
Originally Posted by Sevn86
Oh that's scary! Happy to hear it started back up.
If you had impacted the sensor then it should have turned over fine, not fired and thrown an error code. None of that happened, so you sure it wasn't a coincidence, where was the clicking/grinding noise coming from? Did it turn over normally when trying to start it?
Just curious, Glad it's running now!
Maybe I don't understand what the clicking/grinding noise is but I can't see how MA sensor fault leads to, what sounds like a starter issue?
Hilarious! Do you use laundry detergent to do the dishes and dish soap to wash your car too?
lhgdale
03-23-13 08:23 PM
