Tire Pressure Warning at 37?
I have a GS 350 F Sport. The dealer sold it to me with tire pressure at 45 to 50! One tire was giving a warning of only 26 psi. A tire company suggested I should have all around 35 psi which they did.
Now two the dash is showing a warning on two tires at 37 psi. Should the tires really have pressure over 40 psi to avoid the pressure warning?
I already reset the TPMS.
Check the PSI recommendation on the inside of the driver door. Set all the tires to that, then reset the TPMS.
I believe the sticker says 35 front and 36 rear for F-RWD. Mine drops to 32/33 cold and goes up to 36/37 and 37/38 when moving.
That light should only come on when the psi drops to the 20s.
RWD Texas car here, I insist on 35 warm all the way around, dealer sets it at 37 despite my complaints, must be 35 cold to them. Door panel confirms 35psi.
45 to 50, someone needs their head checked at that dealer, that's ridiculous. I can't think of anything that needs that much pressure.
Tire pressure light
The word 'cold' refers to the car not having been driven for 4+ hours (preferably overnight) and the tires not exposed to the sun's UV rays. If it's summer time in Dallas - that means 'cold' could be say 80°. If it is winter time in Boston - that means 'cold' could be say 30° or lower.
The key is to tweak your tire pressure to whatever your 'cold' tire pressure should be (e.g. 33psi, 35 psi, 36psi) when your car typically starts out on its daily trip. In my case - at this time of year in Dallas the lows at night are ~80°. My garage will be 80°-85° at sunrise. That will be the lowest temperature my tires will be after sitting overnight in the garage - and that is when I want my tire pressure to be at their recommended 'cold' tire pressure. When I pull the car out of the garage and drive it, the ambient temperature will already be 80° or higher, and going higher - up to 100°+. My tire pressure will increase as much as 5 psi or more due to (1) a 25° increase in ambient temperature, (2) heated road surface, (3) rolling friction, and (4) the sun's UV rays.
frankly speaking the recommendations are just what they are - recommendations. GS uses low aspect tires so variations in temperature can cause a wide range in the tire pressure throughout the day. For me, 35psi warm is the best balance of refinement and sport to me so that can be 31-33 psi cold in the morning, depending on how hot it gets in the afternoon.
