Intermittent headlamp out
d4s out sometimes
i have similar issue but only when i am making right turn
not happening every right turn.
did replace bulbs with one from ebuy china d4s but after 3 months same issue.
flip switch on-off and both lights are on .
why is turning off when right turn is engaged,
in fogs put 35w 6000 k hid kit but bulb needs replacement every 2 weeks .
Did anyone notice their headlight beam cutoff not being even between the two sides after install? I kind of expected mine to be a perfect horizontal line at the top. Is that reasonable or usually not the case?
The driver's side is designed to be a bit lower than the passenger's. This is to prevent the headlights from blinding the oncoming traffic. Totally normal.
Ahh okay. Thanks for that interesting tidbit. I thought that I may had done something wrong on the install. Good to know that this is a thing!
had same issue with my headlights on gs450h.
I had replaced bulbs with new philips bulb and still same issue.
I have noticed that while car was idle one of the bulbs started to do flickering .I think ballast needs to be replaced but dealer not selling it separately .It is part of head light assembly.
I put old bulbs back because problem is not in bulbs in my case.
I am still doing a lot of reading and researching in this field.
I like this forum......
cyberseano
12-03-03 09:04 AM
