What kind of Lube do I use for caliper slider pins?
Old 05-18-15, 04:35 PM
xbladex00
xbladex00's Avatar
Default What kind of Lube do I use for caliper slider pins?
Just a curious question... I sort of used anti seize.... I'm pretty sure thats a dumb idea but, i honestly cant find silicone paste in Pepboys or Autozone
Old 05-18-15, 06:00 PM
burny
burny's Avatar
CRC synthetic brake lube at NAPA
Old 05-18-15, 10:12 PM
xbladex00
xbladex00's Avatar
could i use the brake lube that comes in the those plastic baggies? from pepboys? cause thats all i got right now
Old 05-19-15, 06:19 AM
jdmek998
jdmek998's Avatar
We use syl-glide here at work and I use it personally. You can get it from napa or advance auto.
Old 05-19-15, 05:46 PM
sha4000
sha4000's Avatar
Where are you in NY? I see the CRC stuff plus all the other lubes in every Autozone that I frequent. I personally Used the CRC when my wifes brakes started squeaking like crazy. I lubed the pins and the back of the pads which cured the problem. I guess you could use the lube that comes in the packet if you really wanted.
Old 05-19-15, 06:25 PM
xbladex00
xbladex00's Avatar
Alot of say grease is not good because it eats away at rubber...
LexBrett
10-16-15 06:40 AM
ajahearn
19
10-04-15 11:57 AM
lexus-is2
Suspension and Brakes
04-30-13 08:02 PM
mong
13
12-29-12 08:18 AM
98GSOwner
05-30-08 05:57 PM
Quick Reply: What kind of Lube do I use for caliper slider pins?
