Do you have this issue with the GS350?
Hi,
My GS350's RPM meter won't drop if I press break.
It will increase to 2000 then drop back under 1000 rpm suddently.
This is only happened in the early morning(after a night cold down) when I start my car. After minutes ride. It won't happen again.
I notice this issue after I sent the car for a lately recalled by Lexus.
Is it normal? Do you have the same issue with your GS350?
Hi,
Nothing to worry about.
Did you guys read what he posted? RPM jumps up to 2000 when he hits the brakes...
OP - have it checked out. Vacuum brake booster or not the RPM should not jump up. If the engine is decelerating while braking it creates more vacuum with the throttle closed. I've never seen nor worked on a car that was designed to bump RPM up while braking... For the AC compressor operation yes, not to facilitate the brake booster (at least not 1000 RPM).
Now, obviously I am diagnosing your car from my iPad yet what I believe you are experiencing is a "high cold idle". The jump of RPM to 2000 or so is due to the car downshifting while you are braking. That is why you see it drop to 1000 once stopped etc.. High cold idle is a common item with the older 350s. Describe it to your tech/dealership.
Cheers
Cheers
Yes, You are right. I warm up my car in the cold NYC weather. (around 30F- 39F)
If it's in the warm weather, It won't happen. Do I need the dealer ship to check it? Or it's normal?
Hard for me to say what yours is doing exactly but if like mine I would bring it to their attention the next time I was at the shop etc..
Cheers
derekhale
Performance & Maintenance
05-23-10 04:17 AM
