load index for tires
Old 09-28-10, 11:35 AM
ghd8989
ghd8989's Avatar
Default load index for tires
Does everyone ignore this number when they go to a smaller profile bigger tire?
When I called to order some 285/25 20s for my rear tires, they said they didn't have a tire that would be adequate according the load index numbers for the given tire.
Old 09-28-10, 11:52 AM
BinaryJay
BinaryJay's Avatar
As long as it's close it's fine. The load indexes specified are very pessimistic and you would probably have to fill your car with 5 adults and a trunk full of lead before it became any kind of problem.
Old 09-28-10, 11:55 AM
ghd8989
ghd8989's Avatar
That was my contention with the load index. I have seen some boats with the same tires as the ones I was looking at (Chrysler 300 C).
Old 09-28-10, 02:26 PM
rominl
exclusive matchup
rominl's Avatar
i have seen and run tires with not enough load index as well, never had a problem. i can't say it will never have problems, but personally i haven't seen friends with these tires having blow out or related problems
Old 09-28-10, 03:49 PM
I8ABMR
I8ABMR's Avatar
I am on 245/30/20's up front and they are not indexed high enough for the load as well. So far so good. Although I did have a set of Falken FK452s that the tread separated on. That was a bit scary.
Old 09-28-10, 05:44 PM
BinaryJay
BinaryJay's Avatar
What's the index the car requires (I forget) and what are you planning on using? My tires are 93.
Old 09-28-10, 06:21 PM
ghd8989
ghd8989's Avatar
93 as well
Old 09-30-10, 10:24 AM
AndyUK
AndyUK's Avatar
In theory a lower load index tyre should have a slightly higher pressure to compensate.
(The effective load bearing capability of a tyres increases with pressure. Up to a point). Tyres have an easier life at higher pressures and will last longer; with the downside of comfort and perhaps grip.
DshngDaryl
10-29-17 10:48 PM
Curtis2000
RC F (2015-present)
17
08-27-17 04:54 PM
MSOxGs3
12-03-09 03:30 PM
joedoe
Wheels, Tires & Brakes Forum
11-02-06 01:35 PM
1NICESC430
05-14-03 02:47 PM
Quick Reply: load index for tires
