Can you put an additional subwoofer on the stock ML sound system
Is it possible to use the ML amp or ML factory audio unit to add a subwoofer of your own? Has anyone done it or is it not possible?
Leeladisky, Can you enlighten us as to how you found and connected to power for the external subwoofer amp and any details/tips on making the connection to the exisiting ML subwoofer.
Lee
You can add a sub as described above- however the bass will be attenuated by the ML amp because of the DSP circuit in the amp. To do this successfully you need a signal summing device before the amp running an aftermarket amp instead of the ML. I am in the middle of figuring this out....I have heard that there will be no volume control on the Head Unit because it is linked to the ML amp with the DSP circuit. I will post back after I figure this out. This may take a while- so stay tuned...
If anyone has done this successfully - please post the details!
Ty419
03-05-12 06:57 AM
Technique
09-05-06 04:00 PM
