22 rim questions!! mad important!!!!
whats up guys..i have some 20inch asanti right now on my gs 350 and found out my friend is sellin his 22inch auto couture rims..hes goin through some tough times ...hes only sellin for 2000 and wonder i should get it...any suggestions..my only concern is rubbing...let me know guys....
^ why would it rub with the 8.5? really its all about the tires at that point. I thought there was another post in here as of recent with 22's on it? I dont see there being any issue other then I would be too afraid to drive on the road and damage them. I personally would go with 19" for a DD.
i am riding 245/30zr22 front and 285/20zr22 in the rear. i do not rubb at all unless i hit a big dip. i did a lot of work on the car in order for those wheels to tuck in perfect with no rubbing .
i had to shave my front and rear fenders all the way down. i used two part plastic weld to hold my rear and front bumpers on. so no more bolts because thats what my tires where rubbing on. i cut for a couple of days till all the rubbing was gone.
well as for the front i wanted to keep the rubber this on the fender on so i shaved the front fenders ,removed the wheel wells, i also shaved a few more things in the front that were sticking out or that was in the way when the wheel will go in. for the rear i rolled the fenders and shaved a few screws that were close to my tires behind the body as well as the rear bumper brackets..
the wheels were on a 2006 lexus gs300, no rubbing, no problems.. they are now on a 2007 infiniti m35 (lowered 2") and no rubbing.. auto couture 3 pc
I dont think they will clear your brake caliper. Check that first, you could always run small tires and neg camber to counter rubbing
What did you do? I just got a set today I don't know how wide they are but the tires are 255/30/22 and I'm rubbing my strut a little in the front and really rubbing fender well.. Was going to go with 235/30/22 if that will help but don't want to waste money on them if it will still be an issue
