Pulled SEVEN Codes
Old 04-26-16, 07:02 PM
RXGS
RXGS's Avatar
Old 04-26-16, 07:33 PM
iToaster
iToaster's Avatar
P0300 is a random multiple misfire.
P0301 is cylinder 1 misfire
P0306 is cylinder 6 misfire
P0120 is related to the throttle position sensor
P1126 is a code for the magnetic clutch in the throttle motor
P1656 is a code for the bank 1 VVTi oil control valve
You probably have a problem with the throttle body, which will cause load reading issues with the ECU leading to the misfires and associated codes. The VVTi OCV code is not related to the throttle body codes, but usually requires a new OCV.
Old 04-26-16, 10:38 PM
Mcon
Mcon's Avatar
Check this thread;
527740-help-me-code-p0120-p0121.html
Old 04-27-16, 09:38 AM
Mcon
Mcon's Avatar
The code tell you what is your idle issue. I hope my car tell me a code, but not. :-(
Old 04-28-16, 08:00 AM
kevin3344
kevin3344's Avatar
Last time this happened to me with VSC/VSCOFF the car bogged down and wouldn't let me go over 25 mph. Once I turned it off/back on I was able to drive it to the dealer. Once there they diagnosed it as a bad TPS. But when I went to pick up the car, I got about a mile away and the problem happened again. Turned right around and took the car back. Told them it was still an issue and after another diagnosis they said I needed to replace the entire throttle body.
Old 04-28-16, 01:45 PM
Mcon
Mcon's Avatar
Originally Posted by 02SDGS
Cleared the codes, and the only codes that came up were p0300 p0301 and p0306 this time around.
Check your electric wires in your connectors for the coils. Some vary said this to you before.
P0301 is cylinder 1 misfire.
P0306 is cylinder 6 misfire.
Old 04-28-16, 01:49 PM
Mcon
Mcon's Avatar
Look what I found the last time on my connector of my coils. Specially the first coil.
I just repair those cables.
Old 04-29-16, 09:17 PM
Mcon
Mcon's Avatar
2SDGS;9466355]^Mcon, my cables did look like that so i used electrical tape to isolate the wires. Did you by any chance pull the spark plugs? Would this cause some sort of liquid to form in the cylinder?[/QUOTE]
Actually yes ,I did it, because I want to install a new spark plugs and everything in that area was dry.
Question for you 02SDGS,
Do you recently work on your throttle body? I think you made another thread recently and you said that you change the valve cover gasket, right? So, if you doing that, you maybe accidentally drop some kind of fluid inside in that area and you don't putting attention of that when you doing the repair on your valve cover. Clean all that area and may sure you no have any hose crack or broken that made that fluid go there. The hose on the intake manifold is what I try to pointing to you. Good luck
Old 05-04-16, 12:21 PM
RXGS
RXGS's Avatar
A bad TPS was causing my issues.
Old 05-05-16, 07:10 PM
FiveSeven
FiveSeven's Avatar
Hey did you get this covered by the class action lawsuit?
Old 05-05-16, 07:13 PM
RXGS
RXGS's Avatar
Nope, paid for it.
Old 05-06-16, 06:21 PM
Mcon
Mcon's Avatar
I thought the cover lawsuit was to March 2016 Maybe I wrong.
Old 05-06-16, 08:35 PM
FiveSeven
FiveSeven's Avatar
doesn't that mean the coverage has lapsed? Im in the market for the 2G GS and was wondering up to when this will be covered.
joeyfres
IS - 1st Gen (2001-2005)
12-05-16 06:43 AM
2jNoise401
05-16-16 09:37 PM
islexusred
01-29-14 07:50 PM
Rollaboy
02-21-11 01:43 PM
w_star_001
Performance
02-21-07 11:22 AM
Quick Reply: Pulled SEVEN Codes
