Car starts and immediately dies after replacing accelerator pedal position sensor.
Old 09-04-15, 05:11 PM
tHunt93
tHunt93's Avatar
Default Car starts and immediately dies after replacing accelerator pedal position sensor.
The title pretty much says it all. Everything's completely reassembled and I'm pretty baffled... Part 22060-50011 on a 98 GS400.
Old 09-04-15, 05:55 PM
kit cat
kit cat's Avatar
It's a long thread but read this thread from the last page first.
Also, the title doesn't help much. What year is your GS, which model (GS300 / GS400 / GS430), list of check engine lights (if any), etc.
PS: okay i obviously can't read... you said it's a GS400. my bad.
Old 09-04-15, 06:51 PM
lexo98
lexo98's Avatar
I could be completely wrong since there are so many names for this part. When I replaced it on my gs300 I had the same problem because I didn't notice that it was spring loaded. When it's installed there are ears on the inside that need to line up. When your putting it in it has to twist so there is tension on it. That unit opens the throttle body not the actual accelerator cable
Old 09-04-15, 07:17 PM
MikeFig82
MikeFig82's Avatar
Double check your work make sure everything is connected. Could be a loose connection, disconnected vacuum hose etc etc.... I recently had a CE for the APPS turns out it was the actual TCM. If you have an OBDII scanner are you getting any codes?
Old 09-04-15, 07:20 PM
Mr Jokster
Mr Jokster's Avatar
You're thinking the TPS sensor, not the APPS (as he's describing),
OP Stupid suggestion, but is it plugged in? Also, you can try repositioning the TPS to give more throttle. Also, you could try resetting the ECU in the case the sensors need to relearn communication.
When starting the car, as soon as it fires up, see if you get throttle when you press down. If you dont, then try again restarting it, but press all the way down to the floor once it fires up (which will give you 10% more throttle mechanically rather than electronically). I'm willing to bet that resetting will fix the problem and/or repositioning the TPS.
Did you remove the TPS for any reason while replacing the APPS? Thats the only reason I can think of that the car wont stay on. Replacing the APPS shouldnt cause this issue.
matthewlee
02-22-18 12:33 PM
bstarr34
Performance
10-27-14 07:49 AM
sivikvtec
06-28-14 06:24 AM
gs4ca
07-01-11 07:14 PM
99Aristo
10-04-10 08:11 PM
Quick Reply: Car starts and immediately dies after replacing accelerator pedal position sensor.
