2002 GS300 Heater Problem
Old 09-23-13, 11:45 AM
sbushnak
sbushnak's Avatar
Default 2002 GS300 Heater Problem
Hey all,
I need some help with my friend's 2002 GS300 heater. It has 170K miles
Problem is that the heat is only working on the passenger side and not the driver side.
I did some research and read about the servo motors for the driver side. We got it out and it seems to be working perfectly. It moves as you change the temperature for the driver side.
I tried to move the white arm by hand and still the air coming from the driver side is lukewarm at best. It is definitely no where near 85 when we set the climate control.
Now the A/C will work on both sides with no problem and the heater is working great on the passenger side.
My next step is to check the other 3 servos on the passenger side to confirm they are all working.
More info about the car:
170K miles
Radiator + thermostat replaced
We flushed the coolant last week and will do so again this Monday
Both heater core hoses near the firewall are hot
If you need anything else please let me know.
Can anybody help with any advice or what should we do next?
Thanks in advance!
Old 09-24-13, 06:34 AM
pmazur
pmazur's Avatar
i have the same problem just opposite side.....passenger side blows cold
2004 ES330
Old 09-24-13, 01:45 PM
sbushnak
sbushnak's Avatar
2004 ES330
Yes it is a common problem but you might get better help posting in the ES section.
Bump? Anybody have an idea about my problem?
Old 12-16-13, 07:01 PM
ssdjoey
ssdjoey's Avatar
im having the same problem except mine is the passenger side not getting warm and when i start the vehicle i hear a motor sounds in the dash (like the servo motor running?)for 15 seconds exactly not sure which servo to replace
Old 12-14-15, 05:50 PM
01GSGUy
01GSGUy's Avatar
I am having the same issue 2001 GS300, I only get heat from passenger side, even the middle center vent blows hot on the right center, and cold on the one to the left of it... super frustrated. I followed all the suggestions, I took the glove box off and i can physically see all 3 servos working the one on drivers side works too.. what the heck can this be????? I am cold on drivers side... help
Old 01-05-17, 10:55 AM
dmoller
dmoller's Avatar
Default Accessing Driver Side Servos
I'm having the exact problem(s) mentioned here, although I believe the Mode servo is working as I can direct air to the various vents. Interestingly, if I don't run the fan, and have the air set for 'Fresh', I do get a little bit of hot air entering the cabin.
I've found videos about removing the glove box to access those two servo motors, but how do I access the driver side servo motor. I've removed a couple of screws and about three nuts in the panel beneath the steering column, but the panel(s) are not coming off.
Thanks,
Dale
Old 01-28-17, 11:43 AM
FreedomRydr
FreedomRydr's Avatar
I am having a similar problem in my 2001, i.e., All sides. Servos are fine as air is blowing on all vents on all settings, but its COLD. Just got this old car, so it is all new to me! I was thinking of starting with T'stat, but if there isa simpler fix to look at first, I would appreciate some suggestions.
Thanks
Doug
Old 02-06-18, 06:21 AM
WalkerVD
WalkerVD's Avatar
Thanks,
Dale
Hi Dale,
I know it's been some time, but were you able to open the driver side to re place those servos?
are there any on the drivers side?
is this an easy to moderate job for a newbie to do?
Thank you for your time
ICGS3
01-26-21 07:41 AM
dmputian
02-23-17 11:16 AM
drivenGS
10-25-15 03:51 PM
leeadrian
04-21-15 08:16 AM
T8LEX
12-09-10 07:08 AM
Quick Reply: 2002 GS300 Heater Problem
