Hessitation, Acceleration, and Rough Idle...Need Help
Old 06-03-13, 08:11 PM
danielaj
danielaj's Avatar
I checked the resistance on the OCV tonight. I pulled 9.6 ohms...I'm not sure what the specs are??? I found some specs under the 1st Gen RX thread a spec of 6.9-7.9...I wonder how different the solenoids are?
Anyone know what the ohm specs are for a 2nd Gen GS300 2JZ-GE
Old 06-03-13, 08:47 PM
Shagnasty
Shagnasty's Avatar
I know you said you checked for vacuum leaks. Did you pull off the hoses? I was having the same symptoms and one of my vacuum lines was clogged up. wouldn't hurt to change pcv valve also.
Old 06-03-13, 10:17 PM
DosyBoy
DosyBoy's Avatar
I would just replace it and see if it will solve your problem, u can always return the ocv if it doesent solve your problem....
Old 06-04-13, 04:32 AM
SaiyanGS3
SaiyanGS3's Avatar
Learned something new. Wow, I didn't know there was a filter screen on the OCV. I wonder if this requires any maintenance?
Old 06-05-13, 08:30 PM
vijayn
vijayn's Avatar
Hey bud, Have you checked the emission devices and hoses going to and from them?
Does your problem have any effect on hard acceleration (loss of power)? Does it happen when its cold or warm or both?
When you changed your throttle body, did you also change your throttle motor?
Things that affect the idle are -
- air leak after maf sensor
-maf sensor
- throttle control system (throttle body, motor ,TPS)
- lines going to and from the throttle area
- emission devices (pcv, charcoal canister, egr)
- possibly leaking injector
- ignition system weak
There maybe more but these are the ones I can think of right now
nyjah
04-11-18 06:02 PM
2haloz
Performance
17
02-19-15 10:35 PM
jporchia
SC- 1st Gen (1992-2000)
10-29-13 08:29 PM
JaxonMac
07-08-09 06:22 PM
stokdd
Performance & Maintenance
11-16-06 05:35 PM
Quick Reply: Hessitation, Acceleration, and Rough Idle...Need Help
