broke ABS/VSC sensor on suspension install, DIY threads have no more pics :(
Old 10-03-13, 05:28 PM
  #31
RXGS
RXGS's Avatar
One of my sensors is broken (according to the code reader), but the vsc/abs/vsc off light are not illuminated. I' just wondering why if this isn't the care for everyone else. The only light on is the CEL and im assuming its on for my bad o2 sensor.
Old 11-18-15, 05:36 AM
  #32
PandaGS300
PandaGS300's Avatar
Anyone have pics of where the wire goes up to? How do you unplug the wire from the car side not he hub?
I need to test mine out and wasnt sure what panels if any need to be pulled off.....
Old 11-18-15, 07:10 AM
  #33
Alphaman19
Alphaman19's Avatar
Just trace it with your hand. It snakes from the hub/spindle, jumps across the strut and travels just under the inner wheel well plastic stuff. Takes all of 2 min to remove once the wheel is out of the way.
Old 10-09-16, 06:54 PM
  #34
lexo98
lexo98's Avatar
OK so the sensor plug-in is inside of the wheel well. Does anyone know where the second portion (from the wheel well clip to the engine compartment) goes to? I pulled on some wires in the engine bay too hard. Stupid move I know, but it looks like the wires go somewhere under the battery tray.
update: I should have added that the wires tore and I spliced them together I disconnected the battery to reset the light and it stayed on so I thought I needed to look for other breaks in the wires since I yanked on them. This morning on the way to work about a block down the street the lights turned off
JeffTsai
05-12-23 04:37 PM
cm0nkey
Suspension and Brakes
03-04-15 09:47 PM
danny10989
12-04-08 05:12 PM
taeng
10-22-08 05:07 PM
drewefx
06-13-08 10:53 AM
Quick Reply: broke ABS/VSC sensor on suspension install, DIY threads have no more pics :(
