P0441 CEL solution
P0441 CEL solution
thanks to CL once again, a very minor issue has been resolved on my car without spending a penny. two days ago my CEL flashed up. i hooked up my actron scanner and found a P0441 EVAC code. after searching this issue on ClubLexus forums, i found the root cause. a vacuum hose was disconnected...reconnected and problem solved. now why this hose became disconnected i'll never know, but it was and reconnected solved the problem. follow the link to the CL thread below and note the hose with the green tab had become disconnected as shown on the first picture.
https://www.clublexus.com/forums/gs-...446-p0441.html
CLUBLEXUS is the ultimate Lexus owners tool...be sure to share your experiences with this great community.
I had the same issue the other day. The car ended up in Lexus Northside and I lost $1700.. They replaced the charcoal canister plus VSV valve. Also try to check the connectors in emission system. The CEL didn't go away after charcoal canister n VSV vakve was replaced. But finally it was gone after they cleaned up emissions connector. God luck!
mds1303
RX - 1st Gen (1999-2003)
12-23-15 11:59 PM
Piraiba
12-03-13 04:07 PM
