Car wont start Help
Old 05-24-06, 01:59 PM
Jujharoo
Jujharoo's Avatar
Default Car wont start Help
Hey whats up ,
I had locked my car keys in the car (actually in the trunk) I called the lock smith he poped the door lock open and I got the keys ou t of the trunk.
Now the car wont start. When the lock smith poped the door lock open the car alarm went off. He said it might be that you need to reset the alarm...?
I got power, ignition turns on, but car wont start, wont even crank.
Any idea what might be worng?
would appreciate any help.
Thanks
Old 05-24-06, 02:04 PM
lalexusgs
lalexusgs's Avatar
Did you just try simple ECU reset by unplugging the battery connector?
Old 05-24-06, 02:40 PM
Jujharoo
Jujharoo's Avatar
Yeah I did that. Left it disconnected for about 30 mins
Old 05-24-06, 02:55 PM
Dx3
Dx3's Avatar
Try closing the door and locking the door, then put the key in the door and unlock it.
That should fix it.
jonny
Old 05-24-06, 02:56 PM
bighenet
bighenet's Avatar
same thing happen to me, you going to have to tow the car to lexus, because lexus told me you try to force the car so it shut it self down there is absolutly any thing you can do, sorry buddy tow it to the neares lexus dealer.
Old 05-24-06, 04:26 PM
Lexbox
Lexbox's Avatar
I was thinking the same thing. Either the stock alarm did it or the aftermarket alarm did it. One thing you can do if you want is to bypass the ignition kill switch wire by reconnecting it. It is the FATTEST wire coming out of the aftermarket alarm and may even be brown. That will only work if the aftermarket alarm did it though. gl
Edited: On second thought the ignition wire I spoke of might actually be the starter kill wire. Its been so long since I wired up an alarm I forgot. Either way its still more than likely brown and still the fattest wire.
Old 05-25-06, 09:41 AM
Jujharoo
Jujharoo's Avatar
I guess Im gonna have to tow it to the dealer. I tried nothing worked.
The car has stock alarm. No after market stuff.
BTW thanks guys
AnthonyMtz
RX - 1st Gen (1999-2003)
19
05-29-14 11:50 AM
onebad2jz
SC- 1st Gen (1992-2000)
01-25-12 08:09 PM
tccsmith
13
01-12-11 06:08 AM
maikeru
09-30-08 05:29 PM
FILIPE
Performance
01-01-03 05:04 PM
Quick Reply: Car wont start Help
