Battery problem
Battery problem
I have had the battery replaced twice in my 2013 ES350 in the past 6 months. Has anyone had problems with the battery? Dealership suggested that the key not be placed near a cellphone or other remote device. Also hinted that I am not turning the car off correctly. This is my third Lexus ES and I never had this problem before. Any ideas?
I don't leave a key in the car, but I have one in the garage. I will move it and see if that helps. Is this a problem with 2013, because this is not a problem with my 2012 HS nor 2009 ES?
Can't answer that. Perhaps the 2013 is more sensitive compared to the earlier models or the HS. Did you have a remote fob (not just the remote key) in those too?
You can put the remote into a "battery saving" mode.
From page 129 of manual:
Electronic Key Battery-Saving Function
When battery-saving mode is set, battery depletion is minimized by stopping the electronic key from receiving radio waves. Press (unlock button) twice while pressing and holding (lock button). Confirm that the electronic key indicator flashes 4 times. ... To cancel the function, press any of the electronic key buttons.
Alternatively, just keep the spare key away from the car.
If you keep a remote key fob too near the car, it will talk with the car constantly, and run down the battery.
And, read pages 710-711 of the manual. Then buy a few CR2032 batteries and keep them as spares. The batteries are cheap enough I really don't worry about the cost -- less than a buck each.
Do those other vehicles have push button start or do they have a conventional key? The battery drain issue when a fob is left in or near the vehicle only applies to vehicles with push button start, and it does not apply to vehicles with a conventional key that is used to start or enter the vehicle.
Yonny
08-17-18 12:30 PM
