ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Help removing interior piece (B-pillar?) please.
Old 06-18-15, 07:16 AM
codejd
codejd's Avatar
Default Help removing interior piece (B-pillar?) please.
This rattle by my left ear (driver's side) is driving me crazy so I've decided to remove this piece that holds the seat belt mechanism but I can't quite figure out how to proceed without risking damage. Should I just pull & pray or if the other pieces (lower trim, scuff plates) need to be removed as I seem to remember seeing a TSB on another Lexus make (GS?) that eluded to the latter.
Any help would be appreciated.
TIA!
Attached Thumbnails Help removing interior piece (B-pillar?) please.-2015-06-18-08.09.12.jpg
Old 06-18-15, 08:25 AM
nevernu
nevernu's Avatar
they pop off easily, start at scruff plate and work way up, notice 2 bolts on upper garnish . I foamed the inside of the adjuster to minimize that rattle
File Type: pdf
Old 06-18-15, 10:42 AM
codejd
codejd's Avatar
Did it work?
So the scuff plates pull up and pop off, ditto with the lower pillar trim then 2 screws and a pull on the upper pillar trim, right?
Cheers!
Old 06-18-15, 04:10 PM
ESh
ESh's Avatar
How you foamed the inside? Does it work?
Old 06-20-15, 04:34 PM
Blueshark
Blueshark's Avatar
As i remember in the past, the only part on the B pillar that takes knocking noise when hitting bumps is the plastic part that can be seen from the outside of the B piilar, no need to open the pillar. The part is the one that you have to press to adjust the height of the seat belt. For the part to move, i has to slide, so a little play makes it knock.
I've tried inserting a thin foam or felt to reduce the play and yes it does stop the knocking, but you impair the sliding mechanism, so it's a trade off. Unless you can find a very thin piece of felt and use double sided tape, it can be done and you need only a very very small piece of felt, i mean in the milimeters. The point is to make the mechanism slide freely , but prevent it to hitting each other.
So i left it alone and live with it, mine doesn't make a lot of noise.
462HO
01-18-18 09:53 AM
yakuza161
08-04-17 04:08 PM
Stylz79
RX - 3rd Gen (2010-2015)
10-08-16 01:48 PM
Bankswood
SC- 1st Gen (1992-2000)
12-17-15 09:54 AM
430keeper
11-12-14 02:54 PM
Quick Reply: Help removing interior piece (B-pillar?) please.
